Channel Not Found - Slack
I am trying to send notifications to slack but I am having some issues.
Error:
homeassistant.components.notify.slack: Could not send slack notification. Error: channel_not_found
The below are the config all within the configuration.yaml
notify config
notify:
  - name: slack
    platform: slack
    api_key: _removed_
    default_channel: '#general'
    username: "hass"
automation config
automation:
    platform: state
    entity_id: binary_sensor.up_stairs_motion
    state: 'on'
    service: notify.slack
      message: 'Motion Detected'
      target: ""
Thank you!
Is your bot in the room?
I believe so, General is a public room. I tried a private room called ā€˜Notificationsā€™ and invited the bot and still had the same issue.
Huh weird, when I click the trigger button it doesnā€™t work but now I am getting notifications of things happening.
I am going to have to do more testing when I get home to see what is going on.
I will update you. Thanks fadaff
If I call Developer tools the slack notify - everything works perfect. My api_key already changed.
file notify.yaml:
- platform: slack
  api_key: 'xoxb-75081053286-cDkbuJNwQb78P1GfR12vxQUN'
  default_channel: '#home-assistance'
  username "hass"
I have error in error log:
> 16-10-11 12:58:43 homeassistant.core: BusHandler:Exception doing job
> Traceback (most recent call last):
>   File "/srv/hass/lib/python3.4/site-packages/homeassistant/core.py", line 1224, in job_handler
>     func(*args)
>   File "/srv/hass/lib/python3.4/site-packages/homeassistant/core.py", line 1087, in execute_service
>     service_handler.func(service_call)
>   File "/srv/hass/lib/python3.4/site-packages/homeassistant/components/notify/__init__.py", line 111, in notify_message
>     notify_service.send_message(**kwargs)
>   File "/srv/hass/lib/python3.4/site-packages/homeassistant/components/notify/slack.py", line 76, in send_message
>     for target in targets:
> TypeError: 'NoneType' object is not iterable
this is 76 row:
the function:
    def send_message(self, message="", **kwargs):
          """Send a message to a user."""
        import slacker
        targets = kwargs.get(ATTR_TARGET, [self._default_channel])
        data = kwargs.get('data')
        attachments = data.get('attachments') if data else None
            try:
                self.slack.chat.post_message(target, message,
                                             as_user=self._as_user,
                                             username=self._username,
                                             icon_emoji=self._icon,
                                             attachments=attachments,
                                             link_names=True)
            except slacker.Error as err:
                _LOGGER.error("Could not send slack notification. Error: %s",
                              err)
I see that something wrong in:
What can be wrong?
I have check the kwargs dict:
kwargs: {'data': None, 'target': None}
So it looks that something wrong not here but before in other functions. There is no ā€˜targetā€™ key dict value. That is why system goes to the error.
In case of using DevTool:
notify/notify with { "target": "#home-assistance", "message": "testing slack" }
we have everything good and dict is:
kwargs: {'data': None, 'target': ['#home-assistance]}
So why with my automation it is not works:
#automation 9:
 - alias: Update family home
      - platform: state
        entity_id: group.family
        to: 'home'
        for:
          hours: 0
          minutes: 2
          seconds: 0
      service: notify.notify
       message: 'Somebody came home!'
So fix it by adding simple condition.
after:
   targets = kwargs.get(ATTR_TARGET, [self._default_channel])`
add this two lines:
if targets == None:
   targets = [self._default_channel]
And will be waiting for new release. Many thanks.
Can reproduce it and opened an issue.
Iā€™m using HASSIO with 0.65.4 and Iā€™m getting this problem too.
2018-03-15 22:20:54 ERROR (SyncWorker_4) [homeassistant.components.notify.slack] Could not send notification. Error: not_in_channel
The strange thing is this happens for the below script:
  - service: notify.slack
      message: "Test Message"
But works fine whenever I do a notification that has a File or URL attached like below. Can someone help???
    data_template:
      title: >
        You have Mail - Parcel Chute just opened
      message: >
        Parcel Chute just opened, {{now().strftime("%A %H:%M:%S %d-%m-%Y")}}
        file:
          path: /config/notify/FRNTMAIL.jpg
I figured out my problemā€¦ it was because the bot was not in the #general channel.
To add the bot to the channel using the slack app I simply wrote a message @mybot in the #general channel and that asked if I wanted to add the bot to the channel. After doing so my problems were resolved.
