Cheap outdoor PTZ Cameras
Hi all,
I’ve seen a number of posts on here about cheap outdoor PTZ cameras but wondered if anyone has had success with cameras from LS Vision? There are some interesting cameras by this company on Aliexpress and wondered if anyone had any success with adding these to home assistant. Particuarly interested in using with Frigate. Suspect they are rebranded under many different names
The cameras in question are:
  • LS Vision LS-WL341
  • LS Vision LS-WQ1-G
    Says they support onvif but aware to not always trust its true or a tinkered version that isn’t 100% standard.
    One says uses an app called IPC360 Home so possibly both use the same?
Are these worth a shot or would it be better to stick with a known quantity such as HikVision compatible? These are about 3 times the price, but probably for good reason.
Currently using and cheap ICSee PTZ camera but after about 3 years, it seems to be giving up the ghost and isn’t the greatest.
