I have been having no luck getting this to display what I want yet, I have gotten it to work so I know it is not hardware.
I am trying to use the lvgl library with an arc but get a myriad of errors so I decided to just try the esphome cookbook lvgl examples and go from there. I have tried several and get this error
ERROR Error while reading config: Invalid YAML syntax:
mapping values are not allowed here
in "/config/esphome/cyd-1.yaml", line 159, column 10
The code is below and line 159 is the one that begins with pages.
binary_sensor:
- platform: homeassistant
entity_id: light.dining_room_lights
publish_initial_state: true
on_state:
then:
lvgl.widget.update:
state:
checked: !lambda return x;
lvgl:
pages:
- id: room_page
widgets:
- button:
align: CENTER
width: 100
height: 70
checkable: true
widgets:
- label:
align: CENTER
text: 'Remote light'
on_click:
- homeassistant.action:
action: light.toggle
entity_id: light.remote_light
Full config
# Basic yaml code to get the ESP32-2432S028R display to work in ESPHome.
# This yaml displays the ESPHome logo and the current date and time.
# Written by Jonny Bergdahl
# - [GitHub](https://github.com/jonnybergdahl)
# - [Twitter](https://twitter.com/jonnybergdahl)
# - [YouTube](https://www.youtube.com/jonnybergdahl)
# NOTE:
# In order for this to work you need to add the following settings in your secrets.yaml file:
# - api_key
# - ota_password
# - wifi_ssid
# - wifi_password
# - ap_password
# Create a folder named fonts in your ESPHome folder, and copy the file fonts/Arimo-Regular.ttf there.
# Example file setup
# Change the naming below, they will be the names used in Home Assistant
substitutions:
device_name: yellowtft1
friendly_name: Yellow TFT 1
# Standard ESPHome setup
# ESPHome naming
esphome:
friendly_name: $friendly_name
# The ESP32-2432S028R uses a standard ESP32-WROVER, so we use the esp32dev defintion
esp32:
board: esp32dev
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "retracted"
ota:
- platform: esphome
password: "retracted"
# Setup WiFi credentials
wifi:
ssid: !secret wifi_ssid
ap:
captive_portal:
# ESPHome Display related setup
# Create a font to use, add and remove glyphs as needed.
font:
- file: 'fonts/Arimo-Regular.ttf'
glyphs: "!\"%()+=,-_.:°0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZÅÄÖ abcdefghijklmnopqrstuvwxyzåäö"
glyphs: ":0123456789"
# Create a Home Assistant blue color
color:
- id: ha_blue
hex: 51c0f2
# Create an ESPHome logo image
image:
- file: "images/esphome.png"
type: RGB24
# Home Assistant related setup
light:
- platform: monochromatic
output: backlight_pwm
name: Display Backlight
restore_mode: ALWAYS_ON
# Create a time sensor, this will fetch time from Home Assistant
time:
# Hardware related setup
# Setup SPI for the display. The ESP32-2432S028R uses separate SPI buses for display and touch
spi:
- id: tft
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
- id: touch
clk_pin: GPIO25
mosi_pin: GPIO32
miso_pin: GPIO39
# Setup a pin to control the backlight
output:
- platform: ledc
pin: GPIO21
# Setup the ili9xxx platform
# Display is used as 240x320 by default so we rotate it to 90°
# We print date and time wth the strftime() function, see the ESPHome documentation to
# format date and atime to your locale.
display:
- platform: ili9xxx
model: ili9341
spi_id: tft
cs_pin: GPIO15
dc_pin: GPIO2
rotation: 270
invert_colors: false
auto_clear_enabled: false
update_interval: never
binary_sensor:
on_state:
then:
lvgl.widget.update:
state:
lvgl:
pages:
- id: room_page
widgets:
- button:
align: CENTER
width: 100
height: 70
checkable: true
widgets:
- label:
align: CENTER
on_click:
