I’ve never seen a sensor reporting the values like this, so that’s why the macro doesn’t support it.
But why not use the core EnergyZero integration, and retrieve the prices using the template sensor blueprint?
Yes, I known there is an EnergyZero Core integration written by @klaasnicolaas, but I think he will run into the same ‘issue’ as I have now.
EnergyZero is also switched from hourprices to quarterprices at Jan 1st, 2026.
As far as I know the EnergyZero Core needs to be updated to show the quarterprices too and need to use the new API.
This is being worked on, the python package has already been adjusted, but the integration still needs to be updated.
Hi Klaas,
My REST API is working (electricity and gas), and I get the same results as you have in e.g. Comparing v4.0.1...v5.0.0 · klaasnicolaas/python-energyzero · GitHub
I also noticed that you have nested values?
Will this say that the macro written by TheFes can’t be used in the future?
The action provided by the integration doesn’t return the values like that. Maybe it’s reformatted before the response for the action is returned.
You could still use the template sensor, what is the entity_id of your current sensor which returns the attribute value like you posted above? And which attribute is it?
Wait, I already see it in the code you posted for the macro
template:
- sensor:
- unique_id: energy_zero_reformatted
name: Energy Zero Prices
state: "{{ states('sensor.electricity_market_price_hour_price') }}"
attributes:
prices: >
{% set ns = namespace(prices=[]) %}
{% for i in state_attr('sensor.electricity_market_price_hour_price', 'base') | default([], true) %}
{% set ns.prices = ns.prices + [dict(start=i.start, price=i.price.value | float)] %}
{% endfor %}
{{ ns.prices }}
That should give you a sensor.energy_zero_prices which can be used with the macro
It looks like it’s working the way I’d like it to.
I couldn’t have imagined how you designed that sensor attribute. Lack of knowledge.
I did have to add {{ ns.prices }} to the attribute, otherwise it wouldn’t work.
I’m very happy with this solution.
Thank you very much.
Yeah, forgot to output it ![]()
Good catch
Thanks to your help and support, I’ve now fully switched from the old EnergyZero API to the new API to retrieve energy rates.
Thanks again for all your help, and now it’s time for a nice cup of coffee. ![]()
I have set split = true to get 15min slots. What parameter I can use to tell the script that I want consecutive time of x minutes/hours?
For example: 8 hours, split = true, consecutive block = 2 (at least 30min charging slots)
You can use min_split_hours=0.5
I must start with saying I have not read the whole topic, I have searched though, and cannot find useful info so far.
I am already for while trying to figure out how to make a visual representation of this kind of output, generated with the ‘split’ option.
"start": "2023-09-19T15:00:00+02:00",
"end": "2023-09-19T16:00:00+02:00",
"hours": 1,
"prices": [
-0.004
"is_now": false
"start": "2023-09-20T02:00:00+02:00",
"end": "2023-09-20T03:00:00+02:00",
"hours": 3,
"prices": [
-0.002,
-0.004,
-0.003
"is_now": true
"start": "2023-09-20T12:00:00+02:00",
"end": "2023-09-20T14:00:00+02:00",
"hours": 2,
"prices": [
-0.004,
-0.006
"is_now": false
"total_hours": 6,
"datapoints_per_hour": 1,
"datapoints": 6
Preferrably in a simple bar like so:
(this is historic data, that is easy of course)
Any help appreciated! My knowlegds falls short here ![]()
split=true, mode='is_now' will give you either true or false.
You can use this in a template binary sensor, which will result in a sensor with a bar like that in the more-info card.
If you want such a bar in the GUI, you can use a History Graph Card.
I am using that to steer my ev charger, but it cannot be used to ‘look into the future’ right?
What I would like to see is the charge plan for the next 24 hours
That wasn’t clear from your initial question.
Based on the template output you showed, you can get all the start and end times, and probably you can use Apex charts to plot that into a graph, but I don’t have any experience with that. That’s more of a question for the frontend category.
Sorry for not being clear in the first place and thanks for your suggestion. I will take it to the apexcharts experts!
