hello community,
as always i’ve launched the add-on to check if there are problems with the new update and this time i can’t debug the following error… can someone help me?
[21:42:04] INFO: Installing Home Assistant: latest...
[21:42:04] INFO: Please be patient, this might take a few minutes...
WARNING: You are using pip version 19.1.1, however version 19.2.3 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
[21:45:03] INFO: Installed Home Assistant 0.98.1
[21:45:03] INFO: Don't worry, this temporary installation is not overwriting your current one.
[21:45:03] INFO: Making a copy of your configuration for checking...
[21:45:08] INFO: Checking your configuration against this version...
[21:49:33] ERROR: The configuration check did not pass!
[21:49:33] ERROR: See the output below for more details.
INFO:homeassistant.util.package:Attempting install of colorlog==4.0.2
Testing configuration at /tmp/config
INFO:homeassistant.util.package:Attempting install of hass-nabucasa==0.17
INFO:homeassistant.util.package:Attempting install of restrictedpython==4.0
INFO:homeassistant.util.package:Attempting install of python-nmap==0.6.1
INFO:homeassistant.util.package:Attempting install of getmac==0.8.1
INFO:homeassistant.util.package:Attempting install of yeelight==0.5.0
INFO:homeassistant.util.package:Attempting install of pywebpush==1.9.2
INFO:homeassistant.util.package:Attempting install of home-assistant-frontend==20190828.0
INFO:homeassistant.util.package:Attempting install of androidtv==0.0.24
ERROR:homeassistant.scripts.check_config:BURB
File "/usr/local/lib/python3.7/site-packages/homeassistant/scripts/check_config.py", line 206, in check
async_check_ha_config_file(hass)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 579, in run_until_complete
return future.result()
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/check_config.py", line 156, in async_check_ha_config_file
platform = p_integration.get_platform(domain)
File "/usr/local/lib/python3.7/site-packages/homeassistant/loader.py", line 235, in get_platform
"{}.{}".format(self.pkg_path, platform_name)
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/androidtv/media_player.py", line 6, in <module>
from androidtv import setup, ha_state_detection_rules_validator
File "/usr/local/lib/python3.7/site-packages/androidtv/__init__.py", line 6, in <module>
from .androidtv import AndroidTV
File "/usr/local/lib/python3.7/site-packages/androidtv/androidtv.py", line 9, in <module>
from .basetv import BaseTV
File "/usr/local/lib/python3.7/site-packages/androidtv/basetv.py", line 13, in <module>
from adb import adb_commands
File "/usr/local/lib/python3.7/site-packages/adb/adb_commands.py", line 31, in <module>
from adb import common
File "/usr/local/lib/python3.7/site-packages/adb/common.py", line 25, in <module>
import libusb1
File "/usr/local/lib/python3.7/site-packages/libusb1.py", line 8, in <module>
from usb1.libusb1 import *
File "/usr/local/lib/python3.7/site-packages/usb1/__init__.py", line 61, in <module>
from . import libusb1
File "/usr/local/lib/python3.7/site-packages/usb1/libusb1.py", line 199, in <module>
libusb = _loadLibrary()
File "/usr/local/lib/python3.7/site-packages/usb1/libusb1.py", line 173, in _loadLibrary
return dll_loader('libusb-1.0' + suffix, **loader_kw)
File "/usr/local/lib/python3.7/ctypes/__init__.py", line 364, in __init__
self._handle = _dlopen(self._name, mode)
OSError: Error loading shared library libusb-1.0.so: No such file or directory
Fatal error while loading config: Error loading shared library libusb-1.0.so: No such file or directory
Failed config
General Errors:
- Error loading shared library libusb-1.0.so: No such file or directory
Successful config (partial)
