Check Home Assistant Configuration Error Report
Below is the error report for my Add-on to check my existing build against the latest update. I would like some input as to what this error is referring to. I’m using a reverse proxy and know I need to add the use_x_forwarded_for option, but dont see that as the error.
Check Home Assistant configuration
    copying cffi/model.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/ffiplatform.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/vengine_cpy.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/pkgconfig.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/cffi_opcode.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/lock.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/backend_ctypes.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/vengine_gen.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/cparser.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/verifier.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/setuptools_ext.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/recompiler.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/error.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/__init__.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/api.py -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/_cffi_include.h -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/parse_c_type.h -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/_embedding.h -> build/lib.linux-x86_64-3.8/cffi
    copying cffi/_cffi_errors.h -> build/lib.linux-x86_64-3.8/cffi
    running build_ext
    building '_cffi_backend' extension
    creating build/temp.linux-x86_64-3.8
    creating build/temp.linux-x86_64-3.8/c
    gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/include/ffi -I/usr/include/libffi -I/usr/local/include/python3.8 -c c/_cffi_backend.c -o build/temp.linux-x86_64-3.8/c/_cffi_backend.o
    unable to execute 'gcc': No such file or directory
    error: command 'gcc' failed with exit status 1
    ERROR: Failed building wheel for cffi
    Running setup.py clean for cffi
  Failed to build cffi
  Installing collected packages: setuptools, wheel, pycparser, cffi, toml, semantic-version, setuptools-rust
      Running setup.py install for cffi: started
      Running setup.py install for cffi: finished with status 'error'
      ERROR: Command errored out with exit status 1:
       command: /usr/local/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-e6j111yj/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-e6j111yj/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-g69clycg/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-seqz9p0a/overlay --compile --install-headers /tmp/pip-build-env-seqz9p0a/overlay/include/python3.8/cffi
           cwd: /tmp/pip-install-e6j111yj/cffi/
      Complete output (48 lines):
          No working compiler found, or bogus compiler options passed to
          the compiler from Python's standard "distutils" module.  See
          the error messages above.  Likely, the problem is not related
          to CFFI but generic to the setup.py of any Python package that
          tries to compile C code.  (Hints: on OS/X 10.8, for errors about
          -mno-fused-madd see http://stackoverflow.com/questions/22313407/
          Otherwise, see https://wiki.python.org/moin/CompLangPython or
          the IRC channel #python on irc.libera.chat.)
          Trying to continue anyway.  If you are trying to install CFFI from
          a build done in a different context, you can ignore this warning.
      running install
      running build
      running build_py
      creating build
      creating build/lib.linux-x86_64-3.8
      creating build/lib.linux-x86_64-3.8/cffi
      copying cffi/commontypes.py -> build/lib.linux-x86_64-3.8/cffi
      running build_ext
  ERROR: Command errored out with exit status 1: /usr/local/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-e6j111yj/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-e6j111yj/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'
'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-g69clycg/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-seqz9p0a/overlay --compile --install-headers /tmp/pip-build-env-seqz9p0a/overlay/include/python3.8/cffi Check the logs for full command output.
  WARNING: You are using pip version 20.2.4; however, version 21.3.1 is available.
  You should consider upgrading via the '/usr/local/bin/python -m pip install --upgrade pip' command.
ERROR: Command errored out with exit status 1: /usr/local/bin/python /usr/local/lib/python3.8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-seqz9p0a/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --find-links https://wheels.home-assistant.io/alpine-3.12/amd64/ -- 'setuptools>=40.6.0' wheel 'cffi>=1.12; platform_python_implementation != '"'"'PyPy'"'"'' 'setuptools-rust>=0.11.4' Check the logs for full command output.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
At first sight, it’s the addon itself which is erroring out.
Which one is it, exactly?
Seems you were right. An update appeared and it now functions properly. thanks!
