Checking JSON if array is empt
Hi there,
Before I state my question I will sketch the problem a bit.
For the Home Assistant I use the shopping list integration. Now when I enter specific zones I receive a message with the shopping list. That all works fine. But now I want only send the message when the shopping list is not empty.
I was thinking to check the JSON file and check if the array is empty.
My question is how do I do this? Can I fix this with a template or something else?
Also, if you have a better solution to check if the list is empty please let me know.
Thanks in advance!
have you ever managed to get this working? i was looking for similar functionality tbh
