Hi everyone,
I’m new to home automation and also new to Home Assistant. I must first say how good is HA and how easy it was to install it. I’m running hass.io on a RPi3 and can successfully control some Broadlink Wifi plugs. I want to control my wall switches from HA but my home electrical installation (in Chile) does not have a zero (neutral) wire for the switches. So some easy solutions like Wifi or Zwave switches are then impossible. Some Zigbee switches like the one from Xiaomi only existe existe in EU size and Chile is using the US Size (even if electricity is 230V). My only solution seems to be some RF433 switches that do not need the zero wire.
So I built a RFlink gateway which seems to work pretty well, and bought two cheap chinese RF433 switches based on the EV1527 chip (the FUNRY ST1, one with a single gang and one with two gangs) to make tests. These switches come with a remote control.
When using the first remote control (four buttons), the RFlink detects the following:
20;02;EV1527;ID=0dc21c;SWITCH=04;CMD=ON;
20;03;EV1527;ID=0dc21c;SWITCH=01;CMD=ON;
20;04;EV1527;ID=0dc21c;SWITCH=08;CMD=ON;
20;05;EV1527;ID=0dc21c;SWITCH=02;CMD=ON;
After training the wall switch with this remote, I can control the switch with RFlink using the following commands (no matter if the command is ON or OFF, the switch only take into account the switch number):
10;EV1527;0dc21c;4;ON;
10;EV1527;0dc21c;1;ON;
10;EV1527;0dc21c;8;ON;
10;EV1527;0dc21c;2;ON;
However, the four buttons of the second remote control appear with the following in the Rflink:
20;07;TriState;ID=0a854a;SWITCH=1;CMD=OFF;
20;08;TriState;ID=0a854a;SWITCH=1;CMD=ON;
20;09;Eurodomest;ID=2ab03a;SWITCH=07;CMD=ON;
20;0A;Eurodomest;ID=2ab03a;SWITCH=05;CMD=OFF;
which is very different from the first one. I am wondering if this comes from a detection error from the RFlink (reception quality) or if the remote is really different)? The wall switch does not have any problem to learn these codes and I can control the switch. However, none of the following commands from the Rflink work:
10;TriState;0a854a;1;OFF;
10;TriState;0a854a;1;ON;
10;Eurodomest;2ab03a;7;ON;
10;Eurodomest;2ab03a;5;OFF;
The switch can also learn codes directly from the RFlink like:
10;EV1527;0000100;1;ON;
10;EV1527;0000100;2;OFF;
and this works perfectly.
So, my question is: Is it possible to create a switch in HA using the Rflink platform and use arbitraries RFlink commands (like the previous ones) to control the ON and OFF of the wall switch? Something like the command_on and command_off payloads that exist for other platforms.
I’m also wondering if using a Broadlink RM-Pro gateway and TC2 switches would not be a better or easiest solution (even if it is more expensive)?
Sorry for the length of my post , but any help will be highly appreciated as I could not find any help in the forum (or I missed it).
Thanks for your help.
