Choose connected group
i would like to be able to select witch group a switch is connect to is this possable
You’re going to have to elaborate on this. Do you want this in a template? Do you want this just as information from the UI?
what do you mean with a tempate?
I would lik to have an advanced tab in lovelance were i can choose witch socket is in witch group
So you want to dynamically change switches from group to group? Or do you just want that information displayed. I.E. Switch 4 is in group 2 and group 3. What you’re asking is very vague, can you please elaborate with more than 1 sentence?
This leads me to believe you want to move items from 1 group to another. Is this what you want? If so, that’s not possible yet in home assistant. And if it were to be added, it would be under the configuration tab.
okay thanks then it isn’t posseble yet
thanks
I’ll be honest, I’m kinda surprised that there isn’t an interface for this.
well im going to try to fire somthing ill let you now if i find somthing
i found a way to do it for this i used node red
fist i made 4 input selectors
these can select between
Desk
Werkbank
Overwrite
None
these 4 woeld be in an advanced tab
afbeelding
then i alsow have four switches that are my outputs
normaly not visable
and 2 thate are my inputs(desk and werkbank)
normaly on main screen
afbeelding
this is my flow in node-red
These are all events that trigger when somthing changes
in the first the state of in put button gets chacked if on it will check if the ouput is slected on desk and wil then turn on
if you got any questions feel free to ask
