MiMetz
October 17, 2025, 2:48pm
1
Hi Folks,
pretty new to HA, I want to program an automation which switches two areas of light to on-off, off-on, on-on, off-off using choose sequence syntax and do not find the error.
Enclosed the first part of the choose:
alias: Gartenbleuchtung Ein
description: “”
triggers:
domain: mqtt
device_id: 04b8c76654e541c8174599eda39832b0 #“Ikea Styrbar”
type: action
subtype: “on”
trigger: device
actions:
choose:
conditions:
condition: “{{ is_state(‘light.gartenlicht_kirschbaum’, ‘off’) and is_state(‘light.terrassenlicht_wohnzimmer’, ‘off’) }}”
sequence:
action: light.turn_on
area_id: terrasse
Any hints and tips for me?
Thanx
-Mike
francisp
(Francis)
October 17, 2025, 3:06pm
2
First: format your code properly
Second : show the whole automation
MiMetz
October 17, 2025, 7:46pm
3
Hello Francis,
thanx for the suggestions. Here’s the complete code.
The error message is: Message malformed: required key not provided @ data[‘actions’][0][‘choose’][0][‘sequence’]
description: ""
triggers:
- domain: mqtt
device_id: 04b8c76654e541c8174599eda39832b0 #"Ikea Styrbar"
type: action
subtype: "on"
trigger: device
actions:
- choose:
- conditions:
- condition: "{{ is_state('light.gartenlicht_kirschbaum', 'off') and is_state('light.terrassenlicht_wohnzimmer', 'off') }}"
sequence:
- action: light.turn_on
area_id: terrasse
- conditions: >
" {{ is_state ('light.gartenlicht_kirschbaum', 'off') and
is_state('light.terrassenlicht_wohnzimmer', 'on') }}"
sequence:
data: {}
area_id: gartenlicht
- conditions: >
"{{ is_state ('light.gartenlicht_kirschbaum', 'on') and
sequence:
- action: light.turn_off
data: {}
area_id: terrasse
- conditions: >
sequence:
data: {}
area_id: terrasse
data: {}
mode: single
You have an indentation error. The three lines below the first sequence line need two more spaces at the beginning of each of them.
As @atlflyer mentioned, the first option has an indentation error that makes sequence a child of condition instead of conditions. But, that condition key is also extraneous, and will throw a different error once you fix the indentation of sequence.
All the other conditions entries are using both multi-line quote indicators, >, and quote marks, " … so the templates are not being rendered, they are being treated as literal strings. Use one or the other, not both.
Since you are new to HA, it might be better for you to establish a base of knowledge by using the Automation Editor and basic components like State conditions before you jump into the more nuanced methods like short-hand template condition format.
actions:
- choose:
- conditions:
- condition: state
entity_id:
- light.gartenlicht_kirschbaum
- light.terrassenlicht_wohnzimmer
state: 'off'
sequence:
area_id: terrasse
MiMetz
October 18, 2025, 7:30am
6
Thank you for the analysis and advices.
Later I’ll get in the pc and try to fix it.
-Mike
MiMetz
October 18, 2025, 3:44pm
7
Thanx again,
your hints and tips did help me, fix the automation. Here’s the final code:
-Mike
description: "Durchschalten der Gerätegruppe Terrasse und Gartenlicht"
triggers:
- domain: mqtt
type: action
subtype: "on"
trigger: device
actions:
- choose:
- conditions:
- condition: state
entity_id: light.gartenlicht_kirschbaum
state: 'off'
- condition: state
entity_id: light.terrassenlicht_wohnzimmer
state: 'off'
sequence:
area_id: terrasse
- conditions:
- condition: state
state: 'off'
- condition: state
state: 'on'
sequence:
- conditions:
- condition: state
state: 'on'
- condition: state
state: 'on'
sequence:
area_id: terrasse
- conditions:
- condition: state
state: 'on'
- condition: state
state: 'off'
sequence:
area_id: terrasse
mode: single
