Chromecast goes to standby instead of turning off TV
I have a chromecast connected to a dumb TV in my bedroom. I used to use google home which would let me turn off the chromecast and CEC would turn off the TV but only when using a voice command (home didnt have a button for this). Showing that turning off the TV can be done via chromecast.
I now have home assistant set up and working well but for some reason when i turn off my TV using home assistant (using the button on the entity on my dashboard) it sets the chromecast to standby showing photos.
I’ve searched google and found some threads but most of from a long time ago and theres no real answer to my question.
I would love to be able to turn off the TV via my dashboard it’s possible instead of upgrading the chromecast or TV.
The chromecast is an old one i’ve had it about 6 years.
I have android smart tv with built in chromecast and I can’t shut it off using chromecast. But I can turn it on.
Does your TV support HDMi CEC commands?
If not chromecast cannot turn it OFF.
If TV does support CEC it may just be TV or chromecast setting or you may need to send OFF command via CEC from chromecast to TV
The Chromecast turns off the TV if I use a voice command with Google home or connected speaker. I have also googled my TV model and it does have CEC on all hdmi ports
Is there a way to use the command that is activated when using the voice command ‘turn off tv’ in Google home, but in home assistant?
Are you asking if you can turn off TV through chromecast using HA voice command?
Yes
You can create voice intent that calls CEC off command
No sorry it’s hard to explain. Home assistant doest fully turn off Chromecast which in turn doesn’t turn off my TV by CEC.
I know the Chromecast can turn off itself and the TV by CEC, because when I use use a voice command with Google speaker or assistant it fully turns off the Chromecast and turns off my TV also.
I’m wanting to be able to recreate what the Google voice command does to turn off the Chromecast and assign it to a button on my HA dashboard
I was thinking of this. I forget this requires command sent from host and not media player
Try checking the TV settings.
Some TVs have setting to allow turn OFF via cec. The media players only go to standby but generally send OFF command to TV. Do you use any other devices connected to TV by hdmi?
What happens if you send media_player.turn_off command to chromecast?
