Hi all,
I searched around, but I haven’t been able to find an answer to this issue I am having. I’ve found similar, but they seem to all be related to the Chromecast turning off and not being recognized. I can’t get mine to be recognized at all. I would think that since they are being discovered that I could connect to at least one of the casts manually too.
Problem:
Chromecast will never be discovered by HA’s discovery, regardless of the fact that HA does recognize my chromecasts. It does not display in the dashboard or in any of the discovered
Chromecast cannot be added manually via configuration.yaml, or HA will not start at all. This method provides the exact same error. The only difference is that HA does not start.
Chromecast will not be visible at all in the HA dashboard (or services, and whatnot)
HA Logs:
INFO:pychromecast:Querying device status
ERROR:pychromecast.socket_client:Failed to connect, retrying in 5.000000s
File “/home/homeassistant/.homeassistant/deps/pychromecast/socket_client.py”, line 239, in initialize_connection
self.socket.connect((self.host, self.port))
File “/usr/lib/python3.4/ssl.py”, line 840, in connect
self._real_connect(addr, False)
File “/usr/lib/python3.4/ssl.py”, line 831, in _real_connect
self.do_handshake()
File “/usr/lib/python3.4/ssl.py”, line 804, in do_handshake
self._sslobj.do_handshake()
ConnectionResetError: [Errno 104] Connection reset by peer
self.do_handshake()
BUT
It does discover them:
16-12-29 19:33:49 INFO (Thread-13) [homeassistant.components.discovery] Found new service: google_cast (‘192.168.1.18’, 8009)
16-12-29 19:33:49 INFO (Thread-13) [homeassistant.components.discovery] Found new service: google_cast (‘192.168.1.6’, 8009)
Netdisco Output:
Tried this to get the info on connected devices, and make sure that they are at least being discovered.
homeassistant@raspberrypi:~/.homeassistant/deps$ python3 -m netdisco
Discovered devices:
Error fetching description at http://192.168.1.1:8200/rootDesc.xml
google_cast [(‘192.168.1.18’, 8009), (‘192.168.1.6’, 8009)]
netgear_router [(‘R6400’, ‘192.168.1.1’)]
DLNA [‘http://192.168.1.4:64321/bdv-ej-ms.xml’, ‘http://192.168.1.1:8200/rootDesc.xml’]
HASS Setup:
Raspberry PI 2
32GB MicroSD
Wired or wireless connection (have done both. Wireless is 2.4ghz only.)
Fresh install of rasbian
Fresh install of HASS (have tried both manual install and all in one install)
Running HASS in virtual environment
Network:
Netgear R6400
2.4GHz network - Broadcasting SSID, password protected, WPA2-PSK
5GHz network - Broadcasting SSID, password protected, WPA2-PSK
All devices on same subnet (double checked that)
Otherwise, default configurations
Chromecasts:
One classic Chromecast running on my 5ghz wireless network
One Vizio TV with built in smartcast, wired/running on my 5ghz wireless network
Things I have tried:
Reboot Pi
Restart HASS
Configure cast manually (causes HASS to not start at all)
Reinstall/upgrade netdisco
Reinstall/upgrade pychromecast
Reinstall/upgrade HASS
Check configuration to see if the chromecasts are even showing (they are)
Review IPs for both Chromecasts (on the router and on the Pi)
Restart Chromecast
Update Chromecast
Move Chromecast to another display in the house
If you need more info, please let me know! I was really hoping to use this to see my cast devices
