City heating (stadsverwarming) Kamstrup values into Energy Dashboard
I think I’ll try with arduino as well, to put the optical device on the arduino and try to read from there, see if I get a different result
Hi all,
In the past I used a Rpi with USB-IR to read out my Kamstrup 603 meter.
Since my Pi died I want to do this with an ESP. (And preferred ESPHome)
This should be possible with KMP (Kamstrup Meter Protocol [KMP] - ESPHome - Smart Home Made Simple)
Kitlist:
First I hoped that I could read my USB device through the second USB-C port of the ESP32-S3.
This wasn’t working that well. That’s the reason I bought the serial IR-eye.
The IR-eye is connected to the ESP32-S3 by the following:
DCD – 5v
RXD – GPIO17
TXD – GPIO18
GND – GND
I see light in the eye of the IR-device when I check with my phone camera.
Of course I already switch TXD and RXD for testing.
Also other baud rates are tested.
The error I get is :
Received invalid message (prefix mismatch received 0x80, expected 0x40)
If I do debug on the UART, I get the following response:
[17:10:41][D][uart_debug:158]: >>> "\x80?\x10\e\xF9\x00<\x00D\x00c\x00q\x03\xE9\x03\xEC\x1A\xAA\r"
[17:10:42][D][uart_debug:158]: <<< "\x80?\x10\e\xF9\x00<\x00D\x00c\x00q\x03\xE9\x03\xEC\x1A\xAA\r"
The ESP-Home config is the following:
uart:
  - id: uart_bus
    tx_pin: GPIO17
    rx_pin: GPIO18
    baud_rate: 1200
    parity: NONE
    stop_bits: 2
  - platform: kamstrup_kmp
    heat_energy:
    power:
    temp_diff:
      name: Heat Temperature Difference
    flow:
    custom:
      - name: Custom Heat Energy
        command: 0x003C
      - name: Custom Heat Power
        command: 0x0050
    update_interval: 10s
I do something wrong over here. But I don’t know what.
Have you guys got any idea?
I also tried to transform serial to IP (GitHub - oxan/esphome-stream-server: Stream server (serial-to-wifi bridge) for ESPHome),
and then read out the values with HA-Kamstrup_403 (ha-kamstrup_403/README.md at e6a717a62ff9f94be3619f7d2981ec0c4f0465cf · golles/ha-kamstrup_403 · GitHub)
This had no effect and resulted in the same logging.
Config for that one is:
external_components:
  - source: github://oxan/esphome-stream-server
stream_server:
   uart_id: uart_bus
   port: 1234
It seems like the solution with ESP-Home is not working with the MC603.
I found this solution: GitHub - mickkn/ESPxSerialBridge: Serial Bridge for Kamstrup 403 Home Assistents Integration
And integrated with this solution: GitHub - golles/ha-kamstrup_403: Custom component that integrates the Kamstrup 403 heating system into Home Assistant. This component does also support a few other heating systems
Works flawless
Here am I again :slight_smile:
I was wondering why the other solution was working well, and this one didn’t.
Key-part is that RX buffer size is needed at the value of 1024.
Maybe this is something that can be added to the page of the integration?
I also have added the full config with all options.
Credits to @golles where I found alot of info in his coding for getting this complete.
The dates are not imported correctly from the date-objects, those are getting a date in 1970 or something. I think it is the format which need to be changed.
The kit of @cfeenstra is still not working. Maybe the issue are the IR-LED and the photo-LED, but I used the 940nm ones. So it should be right.
https://nl.aliexpress.com/item/1005005371811048.html
If someone knows if these are wrong, please let me know and I order others to test. In the mean-time I use another reading head from AliExpress.
https://nl.aliexpress.com/item/1005005630726621.html?gatewayAdapt=glo2nld
Hereby the full ESP-Home config:
uart:
  baud_rate: 1200
  stop_bits: 2
  tx_pin:
    number: GPIO15
    inverted: true
  rx_pin:
    number: GPIO13
    inverted: true
  rx_buffer_size: 1024
    heat_energy:
      device_id: kamstrup
      icon: "mdi:radiator"
      device_class: "energy"
      state_class: "total_increasing"
    power:
      device_id: kamstrup
      icon: "mdi:flash"
    temp_diff:
      device_id: kamstrup
      icon: "mdi:thermometer"
    flow:
      icon: "mdi:water"
      device_id: kamstrup
    custom:
      - name: Heat Energy (E1)
        device_id: kamstrup
        command: 0x003C
        unit_of_measurement: "GJ"
      - name: Heat Energy to Gas
        device_id: kamstrup
        command: 0x003C
        unit_of_measurement: "m³"
        icon: "mdi:gas-burner"
        device_class: "gas"
      - name: Cooling Energy
        device_id: kamstrup
        command: 0x003F
        icon: "mdi:snowflake"
        device_id: kamstrup
        command: 0x0050
        icon: "mdi:flash"
        device_class: "power"
        state_class: "measurement"
        unit_of_measurement: "kW"
      - name: Temp1
        device_id: kamstrup
        command: 0x0056
        device_class: "temperature"
        unit_of_measurement: "°C"
      - name: Temp2
        device_id: kamstrup
        command: 0x0057
      - name: Tempdiff
        device_id: kamstrup
        command: 0x0059
      - name: Flow
        device_id: kamstrup
        command: 0x004A
        icon: "mdi:water"
        unit_of_measurement: "l/h"
      - name: Volume
        device_id: kamstrup
        command: 0x0044
        icon: "mdi:water"
      - name: MinFlow_M
        device_id: kamstrup
        command: 0x008D
        icon: "mdi:water"
      - name: MaxFlow_M
        device_id: kamstrup
        command: 0x008B
        icon: "mdi:water"
      - name: MinPower_M
        device_id: kamstrup
        command: 0x0091
        icon: "mdi:flash"
      - name: MaxPower_M
        device_id: kamstrup
        command: 0x008F
        icon: "mdi:flash"
      - name: AvgTemp1_M
        device_id: kamstrup
        command: 0x0095
      - name: AvgTemp2_M
        device_id: kamstrup
        command: 0x0096
      - name: MinFlow_Y
        device_id: kamstrup
        command: 0x007E
        icon: "mdi:water"
      - name: MaxFlow_Y
        device_id: kamstrup
        command: 0x0096
        icon: "mdi:water"
      - name: MinPower_Y
        device_id: kamstrup
        command: 0x0082
        icon: "mdi:flash"
      - name: MaxPower_Y
        device_id: kamstrup
        command: 0x0080
        icon: "mdi:flash"
      - name: AvgTemp1_Y
        device_id: kamstrup
        command: 0x0092
      - name: AvgTemp2_Y
        device_id: kamstrup
        command: 0x0093
      - name: Temp1xm3
        device_id: kamstrup
        command: 0x0061
      - name: Temp2xm3
        device_id: kamstrup
        command: 0x006E
      - name: Infoevent
        device_id: kamstrup
        command: 0x0063
        icon: "mdi:eye"
        entity_category: "diagnostic"
        accuracy_decimals: 0
      - name: Infoevent counter
        device_id: kamstrup
        command: 0x0071
        icon: "mdi:eye"
      - name: Serial number
        device_id: kamstrup
        command: 0x03E9
        icon: "mdi:barcode"
      - name: HourCounter
        device_id: kamstrup
        command: 0x03EC
        icon: "mdi:timer-sand"
        unit_of_measurement: "h"
      - name: MinFlowDate_M
        device_id: kamstrup
        command: 0x008C
        icon: "mdi:calendar"
        device_class: "date"
      - name: MaxFlowDate_M
        device_id: kamstrup
        command: 0x008A
      - name: MinPowerDate_M
        device_id: kamstrup
        command: 0x0090
      - name: MaxPowerDate_M
        device_id: kamstrup
        command: 0x008E
      - name: MinFlowDate_Y
        device_id: kamstrup
        command: 0x007D
      - name: MaxFlowDate_Y
        device_id: kamstrup
        command: 0x007B
      - name: MinPowerDate_Y
        device_id: kamstrup
        command: 0x0081
      - name: MaxPowerDate_Y
        device_id: kamstrup
        command: 0x007F
        device_class: "timestamp"
        accuracy_decimals: 2
