I have reviewed and cleaned as much as I can given my knowledge a bunch of sensors that I am collecting from several Awair devices via its local API, but errors related to “the non-numeric class” is really overwhelming and I fail to understand what is lacking or needs to be corrected.
Any hints or pointers are highly appreciated.
Code:
- platform: rest
scan_interval: 60
resource: 'http://192.168.xx.xxx/air-data/latest'
json_attributes:
- timestamp
- score
- dew_point
- temp
- humid
- abs_humid
- co2
- co2_est
- voc
- voc_baseline
- voc_h2_raw
- voc_ethanol_raw
- pm25
- pm10_est
value_template: 'OK'
sensors:
awair_master_bedroom_score:
friendly_name: "Quality Score"
value_template: '{{ states.sensor.awair_master_bedroom.attributes["score"] }}'
unit_of_measurement: "%"
awair_master_bedroom_temp:
friendly_name: "Temperature"
value_template: '{{ states.sensor.awair_master_bedroom.attributes["temp"] }}'
device_class: temperature
unit_of_measurement: "°C"
awair_master_bedroom_humid:
friendly_name: "Relative Humidity"
value_template: '{{ states.sensor.awair_master_bedroom.attributes["humid"] }}'
device_class: humidity
awair_master_bedroom_co2:
friendly_name: "Carbon Dioxide"
value_template: '{{ states.sensor.awair_master_bedroom.attributes["co2"] }}'
device_class: carbon_dioxide
unit_of_measurement: "ppm"
awair_master_bedroom_voc:
friendly_name: "Total VOC"
value_template: '{{ states.sensor.awair_master_bedroom.attributes["voc"] }}'
device_class: volatile_organic_compounds_parts
unit_of_measurement: "ppb"
awair_master_bedroom_pm25:
friendly_name: "Particulate Matter 2.5"
value_template: '{{ states.sensor.awair_master_bedroom.attributes["pm25"] }}'
device_class: pm25
unit_of_measurement: "µg/m³"
Logs:
ValueError: Sensor sensor.awair_living_room_co2 has device class 'carbon_dioxide', state class 'None' unit 'ppm' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: '' (<class 'str'>)
2023-09-29 14:42:24.001 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.util.read_only_dict.ReadOnlyDict object' has no attribute 'voc' when rendering '{{ states.sensor.awair_living_room.attributes["voc"] }}'
2023-09-29 14:42:24.001 ERROR (MainThread) [homeassistant.helpers.event] Error while dispatching event for sensor.awair_living_room to <Job track state_changed event {'sensor.awair_living_room'} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({{ states.sensor.awair_living_room.attributes["voc"] }}) renders=176>: <RenderInfo Template<template=({{ states.sensor.awair_living_room.attributes["voc"] }}) renders=176> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({'sensor.awair_living_room'}) rate_limit=None has_time=False exception=None is_static=False>}>>>
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 588, in state
numerical_value = int(value)
ValueError: invalid literal for int() with base 10: ''
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 591, in state
numerical_value = float(value)
ValueError: could not convert string to float: ''
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 293, in _async_dispatch_entity_id_event
hass.async_run_hass_job(job, event)
File "/usr/src/homeassistant/homeassistant/core.py", line 636, in async_run_hass_job
hassjob.target(*args)
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 1211, in _refresh
self.hass.async_run_hass_job(self._job, event, updates)
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 429, in _handle_results
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 779, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 879, in _async_write_ha_state
state, attr = self._async_generate_attributes()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 820, in _async_generate_attributes
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 785, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 595, in state
raise ValueError(
ValueError: Sensor sensor.awair_living_room_voc has device class 'volatile_organic_compounds_parts', state class 'None' unit 'ppb' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: '' (<class 'str'>)
2023-09-29 14:42:24.011 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'homeassistant.util.read_only_dict.ReadOnlyDict object' has no attribute 'pm25' when rendering '{{ states.sensor.awair_living_room.attributes["pm25"] }}'
2023-09-29 14:42:24.012 ERROR (MainThread) [homeassistant.helpers.event] Error while dispatching event for sensor.awair_living_room to <Job track state_changed event {'sensor.awair_living_room'} HassJobType.Callback <bound method TrackTemplateResultInfo._refresh of <TrackTemplateResultInfo {Template<template=({{ states.sensor.awair_living_room.attributes["pm25"] }}) renders=176>: <RenderInfo Template<template=({{ states.sensor.awair_living_room.attributes["pm25"] }}) renders=176> all_states=False all_states_lifecycle=False domains=frozenset() domains_lifecycle=frozenset() entities=frozenset({'sensor.awair_living_room'}) rate_limit=None has_time=False exception=None is_static=False>}>>>
raise ValueError(
ValueError: Sensor sensor.awair_living_room_pm25 has device class 'pm25', state class 'None' unit 'µg/m³' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: '' (<class 'str'>)
API call output:
timestamp "2023-09-29T16:26:57.175Z"
score 76
dew_point 17.87
temp 27.92
humid 54.41
abs_humid 14.7
co2 496
co2_est 865
co2_est_baseline 37682
voc 2573
voc_baseline 41562
voc_h2_raw 26
voc_ethanol_raw 38
pm25 2
pm10_est 3
