Clear Cut Instructions for adding additional Home Assistant Voice devices
I have installed one Home Assistant Voice and it's working fine.
I'd like to add additional units, so I can have them around in different areas of the house.
But I haven't been able to find clear cut instructions in adding additional devices.
Can someone please point me in the right direction.
Thanks.
Should be the exact same as how you did the first one. You may want to make sure you have the first named appropriately to avoid confusion.
When I try to read the barcode on the device, to add the new device, I get a message:
Something went wrong
Try again or continue without scanning
And I don't see a pairing code on the Home Assistant Voice
And it's looking for an 11 or 21 digit pairing code
The MAC Address is 12 digits, and the S/N is 18 digits
Do I just plug it in?
OK, I'm an idiot, and should RTFM
I was thinking I added it like a regular Matter device.
I've got it.
