Clear_notification no longer works with remote push on iOS
I’m having an issue with clear_notification on iOS. It used to work reliably for me, but it no longer clears the notification.
My versions:
  • Home Assistant Server: 2026.8.2
  • Home Assistant Companion iOS: 2026.7.4
I’m using the documented syntax:
Send notification:
action: notify.mobile_app_mais_iphone
  title: "Test 2"
  message: "Tagged notification test"
    tag: "simple_test"
The notification is received correctly.
Then I send:
  message: "clear_notification"
    tag: "simple_test"
But the notification remains on the iPhone.
I’ve verified that the tag is identical in both calls.
What is strange is that I remember this working reliably in the past with remote push, so I don’t think this is a configuration issue.
I’ve also seen GitHub issue #4304, which seems to describe the same problem. There are reports there of different behavior depending on the Companion App version, but I’m wondering if anyone has found a reliable workaround for remote push on the current 2026.x versions.
Anybody else experience the same issue?
