Hi all - I have a working automation that sends me and my wife a notification if the garage door is left open for a few mins, and we can use that notification to close the door. If one of us does it, it dismisses the notification for us both.
However the garage door can be closed in other ways after the notification has sent (My wife uses the Hue Dimmer Switch in the garage which triggers the door to close, or asks Google to do it).
How can I improve the below automation to dismiss the notification for us both when either the notification is used to close the door or the garage door state returns to closed?
All help hugely appreciated!
alias: Garage Door Left Open - Actionable Notification
description: ""
- type: opened
platform: device
device_id: 8188f35ee988d0f3055299bb6c5b5ad4
entity_id: binary_sensor.external_garage_door_sensor_contact
domain: binary_sensor
for:
hours: 0
minutes: 2
seconds: 0
condition: []
- service: notify.notify
title: The Garage Door is Open
message: >-
The Garage Door was left open at
{{now().hour}}:{{now().minute}}:{{now().second}}
actions:
- action: CLOSE_DOOR
title: Close Door
tag: garage-door
- wait_for_trigger:
- platform: event
event_type: mobile_app_notification_action
event_data:
action: CLOSE_DOOR
- service: switch.turn_on
data: {}
device_id: 9b8f790a0d43d36ef9dabd89e75f1378
message: clear_notification
tag: garage-door
mode: single
The automation triggers, the notification is sent, and can be closed as per the original. But the notification doesn’t clear if the garage door is shit any other way.
Looking at the trace it seems this won’t work because only the trigger that activates it is being carried through (is_open) - the other trigger is greyed out in the trace; given ‘is_open’ triggers the automation it seems like the 2nd choose option would never activate in this scenario.
Any other ideas? Think I’ll need to have a deeper dive into this!
We have the Aqara contact sensor on the door - so simple on/off for open/closed. Then we have a Shelly wired in to the garage door opener which is controlling the opening/closing of the door.
So the first part works as t did previously. But using the garage door sensor being closed in the Triggers section sets off the automation outside the intended use (when it’s open for a few minutes - triggers when the door gets closed).
You mean it triggers when the door has already been closed with the notification?
Yes that is a thing that is hard to remove.
I don’t know if there is a way to find out if the notification is still present on the phone by using the notification sensor.
It’s probably hard to get that working.
But what happens when the clear notification message is sent and the notification is already cleared?
The companion apps support clearing of notifications - the key link is to assign a “tag” to the noficiation when you trigger it and then reference this “tag” when you clear - documentation is here: Introduction | Home Assistant Companion Docs
So when the door closes you would need an automation to clear the notification tag.
Thanks @Hellis81 - I definitely learnt a lot more about how to build automations, and really appreciate the time you took to help.
And thanks @BlackCatPeanut - I kept my original automation, minus the clear_notification part and set this up in a new automation triggered by the garage door closing.
