### Describe the issue you are experiencing
i have since last days after upda…te this error brcmfmac: brcmf_set_channel: set chanspec 0xd0...fail, reason -52
may be the same i see here
[https://github.com/raspberrypi/linux/issues/6049](https://github.com/raspberrypi/linux/issues/6049)
Thanks to help me.
im not a 'system user'..
### What operating system image do you use?
rpi4-64 (Raspberry Pi 4/400 64-bit OS)
### What version of Home Assistant Operating System is installed?
6.6.28-haos-raspi
### Did you upgrade the Operating System.
Yes
### Steps to reproduce the issue
1. When i reboot the system
2.
3.
### Anything in the Supervisor logs that might be useful for us?
```txt
2024-05-13 14:49:33.836 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (486e6e9b_zigbee2mqtt)
2024-05-13 14:49:34.100 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-05-13 14:49:34.101 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-05-13 14:49:34.231 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-05-13 14:49:34.232 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-05-13 14:49:34.252 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-05-13 14:49:34.253 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-05-13 14:49:34.254 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-05-13 14:49:34.255 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-05-13 14:49:34.256 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-05-13 14:49:34.257 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-05-13 14:49:34.383 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-05-13 14:49:34.383 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-05-13 14:49:34.857 INFO (MainThread) [supervisor.host.services] Updating service information
2024-05-13 14:49:34.872 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-05-13 14:49:35.208 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-05-13 14:49:35.227 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-05-13 14:49:35.371 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-05-13 14:49:35.372 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-05-13 14:49:35.372 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-05-13 14:49:37.640 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Linky is stopped, restarting...
2024-05-13 14:49:37.653 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_cf6b56a3_linky application
2024-05-13 14:49:38.362 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/bokub/ha-linky-aarch64 with version 1.4.0
2024-05-13 14:49:45.585 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Linky is stopped, restarting...
2024-05-13 14:49:45.603 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_cf6b56a3_linky application
2024-05-13 14:49:46.335 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/bokub/ha-linky-aarch64 with version 1.4.0
2024-05-13 14:49:53.561 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Linky is stopped, restarting...
2024-05-13 14:49:53.579 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_cf6b56a3_linky application
2024-05-13 14:49:54.338 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/bokub/ha-linky-aarch64 with version 1.4.0
2024-05-13 14:49:54.798 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:50:01.657 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Linky is stopped, restarting...
2024-05-13 14:50:01.675 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_cf6b56a3_linky application
2024-05-13 14:50:02.411 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/bokub/ha-linky-aarch64 with version 1.4.0
2024-05-13 14:50:09.906 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Linky is stopped, restarting...
2024-05-13 14:50:09.928 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_cf6b56a3_linky application
2024-05-13 14:50:10.735 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/bokub/ha-linky-aarch64 with version 1.4.0
2024-05-13 14:50:15.799 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:50:18.021 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Linky is stopped, restarting...
2024-05-13 14:50:18.037 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_cf6b56a3_linky application
2024-05-13 14:50:18.740 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/bokub/ha-linky-aarch64 with version 1.4.0
2024-05-13 14:50:25.892 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-5070' coro=<Addon.watchdog_container() done, defined at /usr/src/supervisor/supervisor/addons/addon.py:1429> exception=AddonsJobError('Rate limit exceeded, more than 10 calls in 0:30:00')>
File "/usr/src/supervisor/supervisor/addons/addon.py", line 1443, in watchdog_container
await self._restart_after_problem(event.state)
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 290, in wrapper
raise on_condition(
supervisor.exceptions.AddonsJobError: Rate limit exceeded, more than 10 calls in 0:30:00
2024-05-13 14:50:36.798 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:50:57.795 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:51:08.630 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from f0e7e328_hassio_google_drive_backup
2024-05-13 14:51:08.643 INFO (MainThread) [supervisor.api.middleware.security] /backups access from f0e7e328_hassio_google_drive_backup
2024-05-13 14:51:18.829 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:51:39.803 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:52:00.800 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:52:21.815 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:52:42.806 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:53:03.808 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:53:14.054 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (486e6e9b_zigbee2mqtt)
2024-05-13 14:53:24.803 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:53:45.798 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:54:06.797 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:54:27.800 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:54:48.797 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:55:09.797 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:55:30.796 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:55:51.793 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:56:12.801 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:56:33.839 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:56:54.799 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:57:15.795 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:57:36.802 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:57:57.794 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:58:18.793 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:58:20.052 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (486e6e9b_zigbee2mqtt)
2024-05-13 14:58:39.799 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:59:00.910 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:59:21.793 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 14:59:42.796 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:00:03.801 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:00:24.787 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:00:45.797 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:01:06.795 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:01:27.795 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:01:48.794 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:02:09.789 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:02:30.796 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:02:51.793 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:03:12.801 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:03:26.763 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (486e6e9b_zigbee2mqtt)
2024-05-13 15:03:30.831 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (486e6e9b_zigbee2mqtt)
2024-05-13 15:03:33.797 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:03:54.800 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:04:15.801 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:04:36.802 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:04:57.801 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:05:18.802 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:05:39.799 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:06:00.800 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:06:21.802 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
2024-05-13 15:06:42.803 WARNING (MainThread) [supervisor.api.ingress] No valid ingress session 2afc3da3f78f2a83e84e0e1b3af90f0b53abf5e2cd39a9ffbf8ab9818558fba4c68a8a128c4ff16f493969e16dcf5c5d02aca14ebfb719f908f3dbfd0a7dec1b
### Anything in the Host logs that might be useful for us?
```txt
2024-05-13 14:04:24.366 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:04:27.694 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:04:31.023 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:04:34.351 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:04:37.674 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:04:39.325 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0x100e fail, reason -52
2024-05-13 14:04:39.326 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd022 fail, reason -52
2024-05-13 14:04:39.433 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
2024-05-13 14:04:39.536 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
2024-05-13 14:04:39.641 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
2024-05-13 14:04:41.305 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd090 fail, reason -52
2024-05-13 14:04:41.305 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd095 fail, reason -52
2024-05-13 14:04:41.305 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd099 fail, reason -52
2024-05-13 14:04:41.309 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd09d fail, reason -52
2024-05-13 14:04:41.309 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd0a1 fail, reason -52
2024-05-13 14:04:41.309 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd0a5 fail, reason -52
2024-05-13 14:04:41.312 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:04:44.590 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:04:47.918 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:04:51.245 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:04:54.574 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:04:57.904 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:01.231 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:04.558 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:07.890 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:11.214 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:14.542 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:17.870 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:21.198 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:24.526 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:27.854 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:31.181 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:34.510 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:37.838 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:41.166 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:44.494 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:47.822 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:51.149 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:54.478 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:05:57.806 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:01.135 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:04.462 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:07.790 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:11.118 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:14.446 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:17.774 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:21.102 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:24.430 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:27.758 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:31.086 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:34.414 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:37.738 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:40.261 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0x100e fail, reason -52
2024-05-13 14:06:40.261 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd022 fail, reason -52
2024-05-13 14:06:40.369 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd026 fail, reason -52
2024-05-13 14:06:40.472 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02a fail, reason -52
2024-05-13 14:06:40.577 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd02e fail, reason -52
2024-05-13 14:06:42.245 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd090 fail, reason -52
2024-05-13 14:06:42.245 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd095 fail, reason -52
2024-05-13 14:06:42.245 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd099 fail, reason -52
2024-05-13 14:06:42.245 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd09d fail, reason -52
2024-05-13 14:06:42.249 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd0a1 fail, reason -52
2024-05-13 14:06:42.249 homeassistant kernel: brcmfmac: brcmf_set_channel: set chanspec 0xd0a5 fail, reason -52
2024-05-13 14:06:42.250 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:45.423 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:48.751 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:52.079 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:55.406 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:58.734 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:06:59.917 homeassistant kernel: audit: type=1334 audit(1715609219.907:660): prog-id=163 op=LOAD
2024-05-13 14:06:59.920 homeassistant systemd-timesyncd[584]: Network configuration changed, trying to establish connection.
2024-05-13 14:06:59.945 homeassistant systemd[1]: Started Journal Gateway Service.
2024-05-13 14:07:00.029 homeassistant systemd-timesyncd[584]: Contacted time server 162.159.200.1:123 (time.cloudflare.com).
2024-05-13 14:07:02.062 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:05.391 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:08.722 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:12.054 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:15.374 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:18.703 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:22.030 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:25.364 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:28.686 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:32.014 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:35.342 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:38.670 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:41.998 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:45.326 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:48.654 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:51.982 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:55.310 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:07:58.638 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:08:01.966 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:08:05.295 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:08:08.622 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:08:11.952 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:08:15.277 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:08:18.609 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:08:21.936 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:08:25.262 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:08:28.590 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
2024-05-13 14:08:31.918 homeassistant wpa_supplicant[517]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
### System information
## System Information
version | core-2024.5.3
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.12.2
os_name | Linux
os_version | 6.6.28-haos-raspi
arch | aarch64
timezone | Africa/Libreville
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 5000
Installed Version | 1.34.0
Stage | running
Available Repositories | 1396
Downloaded Repositories | 56
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 12.3
update_channel | stable
supervisor_version | supervisor-2024.05.1
agent_version | 1.6.0
docker_version | 25.0.5
disk_total | 234.0 GB
disk_used | 13.4 GB
healthy | true
supported | true
board | rpi4-64
supervisor_api | ok
version_api | ok
installed_addons | Terminal & SSH (9.14.0), Mosquitto broker (6.4.0), Zigbee2MQTT (1.37.1-1), Studio Code Server (5.15.0), Node-RED (17.0.12), eWeLink Smart Home (1.4.3), ZeroTier One (0.18.0), Cloudflared (5.1.9), AdGuard Home (5.0.7), Samba share (12.3.1), Home Assistant Google Drive Backup (0.112.1), FTP (5.0.2), ESPHome (2024.4.1), Uptime Kuma (0.12.1), Linky (1.4.0), Network UPS Tools (0.13.0), Music Assistant (2.0.2)
</details>
<details><summary>Dashboards</summary>
dashboards | 4
resources | 33
views | 65
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | 3 mai 2024 à 05:34
current_recorder_run | 13 mai 2024 à 14:47
estimated_db_size | 333.26 MiB
database_engine | sqlite
database_version | 3.44.2
</details>
### Additional information
i think its the same like i see here??
[https://github.com/raspberrypi/linux/issues/6049](https://github.com/raspberrypi/linux/issues/6049?fbclid=IwZXh0bgNhZW0CMTAAAR1gpZXwuzZB6cR5ss5pMXxhSerY9UquKbi9JeeACqeJRQ0jKf6gGedX8pY_aem_AYLmQVNpZzXJX0_tU5J9ZENZiwLRp2-jHhS0bNU-FE74Bs0beqYHo-Ya4uHhcYBFhcOBl-NGzZhZkV6D_YqBuxkT)
but im not a "system user"
thanks to help me
