Climate AC not showing on lovelace
hi all,
Been using this for a long time now, but after an update a few versions back my Mitsubishi AC is not showing up on Lovelace anymore.
I get Entity not available. Although I can see it in Developer tools and control the device from there.
My configuration file looks like this
climate:
  • platform: mitsubishi
    ip_address: 172.16.1.14
    unique_id: climate.master_ac_2
Am I missing something?
I cannot see a mitsubishi integration in home assistant Integrations - Home Assistant
I therefore assume you arre using a custom integration. You don’t say which one? You don’t show your lovelace config. You don’t show your dev tools page.
Thank Nick,
Based on what you asked when I dug deeper I found some updates which fixed the issue.
BTW I’m using GitHub - scottyphillips/echonetlite_homeassistant: A Home Assistant custom component for use with ECHONET enabled Mitsubishi HVAC systems. for Mitsubhishi
Excellent!
