Climate besmart_thermostat
Hi there
I have a “besmart” controller. I found out I can control the temperature at home with “home-assistant.” I found this solution: https://github.com/muchasuerte/home-assistant
Unfortunately, the installation method described is not accurate enough. Where can I find a solution, how to install this add-on?
Thank you very much for your help
