Hi all and thanks in advance.
I currently have tado smart thermostats throughout my house.
I use blueprint advanced heating control v5 integration within my home assistant.
I have a large house and to prevent the boiler from cycling on and off just for 1 room, can anyone help me to set a room (that has a schedule and person detection) to only heat is a specific other room also calls for heat.
Example.
Lounge, dining and kitchen.
I only want the lounge to call for heat if it cools below the set temp, but if the temperature drops in dining or kitchen, I don’t want it to heat, untill the lounge calls for heat.
This stops the lounge calling for heat, then turn off. At that moment the kitchen call for heat then turn off and then the dining.
I would prefer the kitchen and dining temps to drop, the. Only heat when the lounge finally calls for heat.
I hope this makes sense. I want this to stop boiler cycling and making the heating more energy efficient.
