Climate cool to fan mode
Hello
I made an automation that works with my two air conditioning units.
This automation lower the thermostat set point at home so that we fel into air conditioning mode for the summer.
This works very well but the problem is that in cooling mode, the temperature is set to 22.5. but the temperature in the house can drop to 20 degrees, which is not the best for Mrs. hihi.
So I would like to use the average of the thermostats in my house that I have already configured, but I would like my automation to use a set point of 21.8 degrees to give the command to the air conditioning unit to go into fan mode only. When the temperature goes back above the set point of 22.5 the unit goes back into cooling mode at a set point of 22.5 degrees.
Here is the code that I made
alias: Été Automatique HVAC Mode
description: ""
  - platform: time_pattern
    hours: /4
    minutes: 0
  - platform: state
    entity_id:
      - weather.forecast_maison
    attribute: temperature
condition:
  - condition: template
    value_template: "{{ now().month in [ 4, 5, 6, 7, 8. 9] }}"
    enabled: true
  - choose:
      - conditions:
          - condition: numeric_state
            entity_id: weather.forecast_maison
            below: 10.5
        sequence:
          - service: climate.set_hvac_mode
              entity_id:
                - climate.30786325640575_climate
                - climate.30786325640632_climate
              hvac_mode: heat
            enabled: false
          - service: climate.set_temperature
              temperature: 21
              entity_id:
                - climate.thermostat_salon_cusine
                - climate.salle_de_bain
                - climate.thermostat_bureau
                - climate.thermostat_chambre_maitre
                - climate.thermostat_petite_chambre
              temperature: 15
              entity_id:
                - climate.sous_sol
                - climate.sous_sol_chambre_invite
                - climate.sous_sol_salle_de_bain
                - climate.thermostat_garage_2
                - climate.thermostat_garage_1_0
                - climate.thermostat_garage_entrepot
              entity_id:
                - climate.bureau_volet
              hvac_mode: heat
            enabled: false
              entity_id:
              temperature: 23
              hvac_mode: heat
      - conditions:
            above: 12.1
            below: 14
        sequence:
              entity_id:
              hvac_mode: cool
            enabled: false
              temperature: 5
              entity_id:
              temperature: 8
              entity_id:
                - climate.sous_sol
              entity_id:
              hvac_mode: cool
            enabled: false
              entity_id:
              hvac_mode: cool
              temperature: 24
      - conditions:
            above: 14.1
            below: 16
        sequence:
              entity_id:
              hvac_mode: cool
              temperature: 23
      - conditions:
            above: 16.1
            below: input_number.temperature_interieure
        sequence:
              entity_id:
              hvac_mode: cool
              temperature: 22.5
mode: single
Cant some one help my please ?
Thank in avance
Maybe useful for you:
Puppets the AC based on your home temperature, not on what the AC thinks the temp is.
