Is it possible to convert a Climate.entity into a Sensor.entity?
I have smart TRVs in my radiators but some are not reporting the correct room temperature as they are in corners and they also get over heated by the pipe heat.
I have some spare TRVs that I can use to monitor the correct room temperature by locating them remote from the radiator at the other side of the room
I have used Better Thermostat integration successfully using a Temperature Sensor to control the rooms radiator TRV, but it does not work with Climate entities, so I cannot use the spare TRVs, hence Iām wondering if there is anyway to convert the Climate entity into a sensor entity
I could buy a load of Temperature sensors but it seems a shame to do that while I have spare TRVs that could do the same job
Did you ever figure this out?
