I’m trying to make an “away mode” for my Honeywell thermostat that will keep the house between 66 (in the winter) and 75 (for summer time). The idea is to have this script run when no one is home for more than 5 minutes so the house always stays a reasonably comfortable temperature for my dog. My thermostat has a heat/cool setting that will automatically switch between heating and cooling as necessary to keep it within a certain range so I should be able to accomplish this with one script using the climate.set_temperature service and target low and target high options. This is the script:
sequence:
- service: climate.set_temperature
target_temp_low: 66
target_temp_high: 75
hvac_mode: heat_cool
entity_id: climate.tstat_5df596
mode: single
alias: Climate away mode
icon: mdi:thermostat
When I try to test it out I get the following error:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/homekit_controller/__init__.py:101
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: November 18, 2021, 12:43:37 AM (12 occurrences)
Last logged: 12:04:32 AM
[2667381064] conversion from NoneType to Decimal is not supported
[2568226872] conversion from NoneType to Decimal is not supported
[2593986688] conversion from NoneType to Decimal is not supported
[2617891496] conversion from NoneType to Decimal is not supported
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1491, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1526, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 278, in service_handler
await script_entity.async_turn_on(
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 382, in async_turn_on
await coro
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 409, in _async_run
return await self.script.async_run(script_vars, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1219, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 353, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 371, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 571, in _async_call_service_step
await service_task
task.result()
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 213, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 658, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 856, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 695, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 588, in async_service_temperature_set
await entity.async_set_temperature(**kwargs)
File "/usr/src/homeassistant/homeassistant/components/homekit_controller/climate.py", line 376, in async_set_temperature
await self.async_put_characteristics(chars)
File "/usr/src/homeassistant/homeassistant/components/homekit_controller/__init__.py", line 101, in async_put_characteristics
payload = self.service.build_update(characteristics)
File "/usr/local/lib/python3.9/site-packages/aiohomekit/model/services/service.py", line 138, in build_update
value = check_convert_value(value, char)
File "/usr/local/lib/python3.9/site-packages/aiohomekit/model/characteristics/characteristic.py", line 303, in check_convert_value
val = Decimal(val)
TypeError: conversion from NoneType to Decimal is not supported
Does anyone understand what could be causing this error? I’m not really a programmer so I have no idea what any of this means - if I had to guess it sounds like some value that I’m providing HA is not a format that it’s expecting. Could it be the numeric values of the temperature?
