Is there a known problem to set them climate.temperature using home assistant if there is a HMIP-WTH-2 in this room? I have one room with HMIP-WTH-2 and i’m not able to change the temperature using home assistant. In all other 3 rooms without HMIP-WTH-2 if have to problems. There is have another sensor installed to get the temperature
Are the values read correctly and you just can’t set them? If so, i had a similar problem when I changed the entity_id via the gui.
I changed the entity_id. But did it with the others also. I can see all attributes but, there is no way to change it.
The only thing that helped me was to delete the entry from the entity registry file and reset the thermostat. Then I first restarted home assistant and then paired the thermostat again.
Or might the problem be related that I have 2 HmIP-eTRV-B1 in this room?
I got it working. I remove the room in my homematic app and recreated it. Afterwards all works as expected
