Hi and a happy new year to everybody,
I am very new in Home assistant and really inexperienced.
According to the automation example for climate preset_mode in the documentation…https://www.home-assistant.io/integrations/climate/#automation-example
I am trying to automate my climate devices by time. Also I have bulit an extra binary sensor to turn the heat off at anytime the livingroom windows is open.
For some reason the automation is not reliable.
The ‘comfort’ part works quite well. But the ‘eco’ part doesn’t toggle climate to eco in the morning.
After opening and again clothing the window all devices switch to ‘comfort’.
So the ‘comfort’ mode seems to be some kind of dominant.
Would I have to turn the state of automation to ‘off’ somehow or what is the missing part…?
The gateway is a Fritz!Box and the devices are mixed Fritz!Dect301 and CometDect.
I have made sure to set off the integrated time circuit of the Fritz!Box.
As far as I know this should be enough…
I am thankful for any advice or idea to improve my first steps…
Best regards,
Torsten
# zeitschaltung temperatur wohnzimmer eco
- alias: 'wohnzimmer_eco'
platform: time
at: "07:00:00"
service: climate.set_preset_mode
entity_id: climate.wohnzimmer, climate.schlafzimmer, climate.spielzimmer, climate.bad, climate.kueche
preset_mode: 'eco'
# zeitschaltung temperatur wohnzimmer comfort
- alias: 'wohnzimmer_comfort'
platform: time
at: "18:00:00"
preset_mode: 'comfort'
# fenster-offen-erkennung
- alias: 'wohnzimmer switch heat_off'
platform: state
entity_id: binary_sensor.wohnzimmer_fenster_contact
service: climate.set_hvac_mode
data_template:
hvac_mode: >
{% if trigger.to_state.state == "on" %}
off
{% elif trigger.to_state.state == "off" %}
heat
{% endif %}
