I have a template temperature sensor which retrieves values from a json generated by weewx, and these values are in italian decimal format, that is with a ‘,’ not ‘.’
The temperature sensor works fine in my Home Assistant (I can graph its values), except for the climate component which give me this error and doesn’t show any temperature :
ERROR (MainThread) [homeassistant.components.generic_thermostat.climate] Unable to update from sensor: could not convert string to float: '18,7'
I suspected a localization problem so I started hass with locale environment variables, but with no luck:
LC_ALL=it_IT
LANG=it_IT
LANGUAGE=it_IT
LC_NUMERIC=it_IT
This is the configuration:
HA Version: 117.4
Python 3.7.3
- platform: rest
name: Temperatura Camera Letto
resource: http://10.20.30.40/weewx.json
value_template: "{{ value_json.stats.ha.extraTemp1 }}"
device_class: "temperature"
unit_of_measurement: '°C'
scan_interval: 300
climate:
- platform: generic_thermostat
heater: input_boolean.caldaia
target_sensor: sensor.temperatura_camera_letto
ac_mode: false
target_temp: 20
What can I do to let HA understand the comma as decimal separator?
