Climate ventilation advisory with optional notifications and TTS
This blueprint advises when to open or close windows and doors in order to use outdoor air for indoor temperature regulation.
Features
  • Advises when to open windows for cooling
  • Advises when to close windows again
  • Uses indoor and outdoor temperature
  • Checks selected window and door contact sensors
  • Checks weather state and wind speed
  • Checks if at least one selected person is home
  • Notification is optional
  • TTS to selected media players is optional
  • At least one delivery method must be configured
  • Advisory language can be selected: Danish, English or German
Requirements
  • Indoor temperature sensor
  • Outdoor temperature sensor
  • Weather entity
  • Window/door contact sensors
  • Person entities
  • Optional notify target
  • Optional TTS entity and media player
Import
Open your Home Assistant instance and import this blueprint
Raw blueprint URL
https://raw.githubusercontent.com/Hoekeren/home-assistant-blueprints/refs/heads/main/automation/climate_ventilation_advisory.yaml
I've tried to build something similar but great that you already did it! I have troubles importing it though:
while parsing a block mapping in "", line 352, column 7: trigger_id: > ^ expected , but found '{' in "", line 355, column 9: {{ expand(openings) | selectattr ...
let my look at it and i wil be rigth back
I have updatede the blueprint and reuploaded it to Github. I trust this solves the problem- else please let my know.
It worked! Thanks!
Great. Hope it will be helpfull for you​:blush:
