Clock Pro Card — Time & Weather Visualization Engine
HACS Default License MIT Version Downloads
:megaphone: Temporary Notice – Cards Unavailable (RESOLVED)
My GitHub account was unexpectedly suspended, which makes all my HACS cards — ClockPro Card, Floor3DPro Card, and OverlayPro Card — temporarily unavailable. Nothing has been deleted; access is simply blocked.
This may have been triggered by a sudden spike in users and download activity on my cards, which can sometimes activate GitHub’s automated security filters. I contacted GitHub Support, and after a manual review, all restrictions were fully lifted. No policy violations were found.
Everything is now accessible again.
Thank you for your understanding and support.
Your Precision Time & Weather Display for Home Assistant (Clock + Weather Card)
:link: Clock Pro Card (source & documentation):
A professional weather + clock card for Home Assistant Lovelace.
Absolute positioning, customizable typography, SVG icon packs, and flexible layout — designed to be easy to use and powerful.
:backhand_index_pointing_right: Works with any weather entity.
:backhand_index_pointing_right: Optional SVG icon pack support.
:backhand_index_pointing_right: Full YAML config — no dependencies.
:pushpin: Features
  • :three_o_clock: Big stylized clock with customizable spacing & colors
  • :date: Date & day labels
  • :sun_behind_rain_cloud: Weather icon + condition + temperature
  • :round_pushpin: Location label
  • :artist_palette: Fully positionable UI elements
  • :artist_palette: Optional colorful SVG icon pack
  • :sun_behind_cloud: Black & White Cloud SVG Pack (dual‑tone icons)
  • :brain: Smart defaults + full stub config for UI add
  • :triangular_ruler: Configurable card height
:rocket: Installation
ClockPro Card can be installed in two ways:
Method 1: HACS (Recommended)
  1. Open HACS in Home Assistant.
  2. Search for: Clock Pro Card.
  3. Select the repository and click Download.
  4. Restart Home Assistant.
After installation, HACS will automatically register the card as a Lovelace resource.
:pushpin: Method 2 — Manual Installation
  1. Download clockpro-card.js
  2. Place it into:
/config/www/community/clockpro-card/
  1. (Optional) Add your icon-pack.js into the same folder
  2. Add the resource manually:
url: /local/community/clockpro-card/clockpro-card.js
type: module
File paths:
/local/community/clockpro-card/icon-pack.js
Notes
  • No custom repository setup is required, Clock Pro is in the official HACS Default Repository Store.
  • Manual installation is only recommended for advanced or offline setups.
:puzzle_piece: Visual Editor (YAML-Free)
Clock Pro Card includes a built-in Visual Editor for Home Assistant Lovelace.
The editor allows you to configure the card without writing any YAML, while still generating a configuration that is 100% equivalent to YAML.
Visual Editor is not a simplified mode.
It is a full visual representation of the YAML configuration.
:sparkles: Design Philosophy
The Visual Editor follows these core principles:
  • Full YAML-Free: every option can be configured visually
  • YAML-Equivalent: no UI-only or hidden settings
  • One-to-one mapping between editor controls and YAML keys
  • No disabled / magic defaults
  • Consistent positioning logic across all elements
If a setting exists in YAML, it exists in the Visual Editor — and vice versa.
:compass: Editor Structure
The editor is organized into four main sections:
  • General / Card & Background
    Global card settings, entity selection, background and icon options
  • Time / Date / Day
    Position, font and color settings for time, date and day labels
  • Weather Icon / Details / Location
    Weather icon placement, weather text and location label configuration
  • Forecast
    Optional multi-day weather forecast settings
Each section contains only related settings, keeping the editor predictable and easy to navigate.
:round_pushpin: Positioning System
All visual elements use the same positioning model:
  • Vertical: top / bottom
  • Horizontal: left / right
  • Value: number (px) or percentage
This ensures:
  • Consistent behavior across all elements
  • No special cases or exceptions
  • Identical results in Visual Editor and YAML
:abacus: Grouped Settings
Related settings are grouped visually to reflect how they work together.
Examples:
  • Font settings: size + weight + letter_spacing
  • Transform settings: x + y + scale
These settings are displayed on a single row in the editor to improve clarity and reduce visual noise.
:cloud: Entity Selection
The Visual Editor uses Home Assistant’s native entity selector for:
  • weather_entity
  • location_entity
  • sun_entity
Entities are selected directly from Home Assistant — no manual typing required.
:brain: YAML Compatibility
Configurations created with the Visual Editor:
  • Use the same keys and structure as YAML
  • Can be freely edited in YAML after creation
  • Can be switched between Visual Editor ⇄ YAML at any time
Using the Visual Editor does not lock you out of YAML — it simply makes configuration faster and safer.
:bullseye: When to Use the Visual Editor
The Visual Editor is ideal for:
  • Initial setup
  • Layout and positioning adjustments
  • Font, spacing and color tuning
  • Rapid visual experimentation
Advanced users can still rely entirely on YAML if preferred.
:hammer_and_wrench: Usage — Full Example YAML
Copy & paste this full config, then edit values to taste:
type: custom:clockpro-card
weather_entity: weather.home
location_entity: zone.home
sun_entity: sun.sun
pro_icon: true
pro_icon_pack: /local/community/clockpro-card/icon-pack.js,
pro_icons_folder: your-folder-name,
card:
  height: 220
background:
  mode: transparent / color
  color: "rgba(0,0,0,0)"
  radius: 0
  padding: 0
elements:
  time:
    pos:
      left: 12
      top: 0
    font:
      weight: 650
    letter_spacing: -2
    gaps:
      hh_colon: 26
      colon_mm: 26
    colors:
      first_digit: "#ff3b30"
      rest: "#111111"
  date:
    pos:
      left: 14
      bottom: 72
    font:
      weight: 650
    letter_spacing: -0.5
    color: "#111111"
  day:
    pos:
      left: 14
      bottom: 20
    font:
      weight: 750
    color: "#111111"
  icon:
    pos:
      right: 8
      top: 0
    icon:
      color: "#111111"
    transform:
      x: 0
      y: -12
      scale: 1.12
    source: weather
    default_icon: "mdi:weather-partly-cloudy"
  details:
    pos:
      right: 14
      bottom: 68
    font:
      weight: 650
    letter_spacing: -0.2
    color: "#111111"
    pos:
      right: 14
      bottom: 20
    font:
      weight: 800
    color: "#111111"
  forecast:
    show: true        # true / false
    days: 5           # 1–7
    pos:
      left: 16
      bottom: 8
    gap: 18
    day:
      font:
        weight: 700
      letter_spacing: 0.4
      color: "#111111"
      uppercase: true
    icon:
      color: "#111111"
    temp:
      font:
        weight: 700
      color: "#111111"
      format: maxmin   # maxmin | max
:date: 5-Day Weather Forecast (Optional)
ClockPro now supports an optional 5-day weather forecast strip, rendered as a native element using the same positioning engine as the rest of the card.
The forecast is designed to be:
  • Minimal
  • Readable at a glance
  • Fully configurable via YAML
  • Non-intrusive to the main clock layout
:backhand_index_pointing_right: Forecast uses the same weather_entity — no extra sensors or helpers required.
:backhand_index_pointing_right: Automatically falls back if forecast data is unavailable.
:sparkles: What it shows
  • Short weekday label (MON, TUE, etc.)
  • Weather icon (MDI or Pro SVG pack)
  • Daily temperature (max or max/min)
:puzzle_piece: Forecast Configuration
The forecast is enabled via the elements.forecast block.
:information_source: Notes
  • days can be set between 1 and 7
  • Forecast is rendered as a single horizontal row
  • Uses daily forecast data provided by the weather entity
  • Night/day icon variants are automatically handled when available
  • If forecast data is missing, the element is simply not rendered
:bullseye: Design Philosophy
The forecast follows ClockPro’s core idea:
Everything is an element.
Absolute positioning, predictable layout, no magic.
This means you can place the forecast anywhere — bottom strip, corner, or alongside other elements — without affecting the rest of the card.
:puzzle_piece: Options
:cloud: Weather
  • weather_entity — any HA weather entity (weather.home, weather.open_meteo, etc.)
  • location_entity — any zone or sensor that provides a friendly name.
Note: weather entities don’t reliably provide city names — zone or config location is recommended.
:artist_palette: Icon Pack (pro_icon / pro_icon_pack)
  • pro_icon: false (default) → standard MDI icons
  • pro_icon: true → load from pro_icon_pack
Example:
pro_icon: true
pro_icon_pack: icon-pack.js
Pack path can be relative — if it doesn’t start with /, ClockPro will resolve it to the card folder automatically.
A pack file should export an object of SVG strings by condition key:
export default {
  clear: "<svg>…</svg>",
  rainy: "<svg>…</svg>",
  partlycloudy: "<svg>…</svg>",
  // etc…
:brain: Stub Config (UI Add Card)
When users add the card from the Lovelace UI, the following default config is provided:
static getStubConfig() {
  return {
    weather_entity: "weather.home",
    location_entity: "zone.home",
    card: { height: 220 },
    pro_icon: true,
    pro_icon_pack: "icon-pack.js",
    background: { mode: "transparent", color: "rgba(0,0,0,0)", radius: 0, padding: 0 },
    elements: {
       // …full settings as above
:artist_palette: Pro Icon Pack (SVG Files)
ClockPro supports a file-based Pro Icon Pack.
This means:
  • You do NOT edit card JS
  • You do NOT embed SVG strings inside YAML
  • You simply drop your own .svg files into a folder
  • ClockPro will load them automatically via icon-pack.js
You can download the official SVG pack from the repository:
https://github.com/levonisyas/clockpro-card/tree/main/dist/svg
1) Create the icons folder
Create this folder in Home Assistant:
/config/www/community/clockpro-card/your_pack/
This becomes accessible as:
/local/community/clockpro-card/your_pack/
FULL required SVG list (day + night)
Day
  • clear-day.svg
  • partlycloudy-day.svg
  • cloudy.svg
  • rain.svg
  • pouring.svg
  • lightning.svg
  • lightning-rainy.svg
  • fog.svg
  • hail.svg
  • snow.svg
  • snowy-rainy.svg
  • windy.svg
  • exceptional.svg
  • unknown.svg
Night
  • clear-night.svg
  • partlycloudy-night.svg
  • cloudy-night.svg
  • rainy-night.svg
  • pouring-night.svg
  • lightning-night.svg
  • lightning-rainy-night.svg
  • fog-night.svg
  • hail-night.svg
  • snowy-night.svg
  • snowy-rainy-night.svg
  • windy-night.svg
  • exceptional-night.svg
  • unknown-night.svg
If night icons are missing, ClockPro will fallback to the closest day icon.
3) Enable Pro Icons in YAML
sun_entity: sun.sun
pro_icon: true
pro_icons_folder: your_pack
:crescent_moon: Day / Night Support
ClockPro automatically detects night mode using:
sun_entity: sun.sun
When the sun is below the horizon:
  • clearclear-night
  • partlycloudypartlycloudy-night
:artist_palette: Customization Guide
You can tune every element:
Element Property Meaning
time pos left/top
font size/weight
colors first_digit/rest
date/day pos/color positioning & color
icon icon.size/color MDI size/color
transform shift/scale for better visual
details pos/font/color bottom weather text
location pos/font/color bottom location text
:warning: Common Issues
:cross_mark: Temperature shows --
The card looks for these attributes:
  • attributes.temperature
  • attributes.temp
  • attributes.current_temperature
If your weather provider doesn’t expose current temperature, ClockPro will fallback to --.
:hammer_and_wrench: Troubleshooting
  • Make sure icon-pack.js is in the same folder as the card (or provide a full path).
  • If customizing icon pack, clear browser cache after editing.
  • For custom SVG sizes, use the transform block.
:handshake: Enjoy :star: Support
I build these projects for my own needs and share them so others can benefit.
I don’t use donation links — so please don’t buy me coffee :hot_beverage:
If you enjoy this project, simply :star: star the repository.
Your feedback and contributions matter more than coffee.
Any chance you’ll be adding the 12hr time format option to this card? Thanks in advance!
Hi! 12‑hour time format support is on my roadmap. I’m currently working on an upgrade that will allow the card to automatically follow Home Assistant’s global time format (12h / 24h).
This means once the update is released, the card will switch to 12h or 24h depending on your HA system settings — no extra YAML options needed.
Thanks for the request, it’s already planned and will be included in an upcoming version.
