Close cover depending on temperatur sensor - IF ELSE
Hi there,
I’m trying to close a cover and depending on the temperatur it should behave differently:
Temp >= 24° → cover should go to position 60
Temp < 24° → cover should go to position 0
Here’s my code in the automation:
- id: 'xx'
  alias: xx
  description: ''
  - event: sunset
    offset: +00:20:00
    platform: sun
  - at: '19:00'
    platform: time
  condition:
  - after: sunset
    after_offset: +00:20:00
    condition: sun
  - after: '19:00'
    condition: time
  - data:
      position: '{% if states("sensor.temp_schlafen")|float >= 24|float %}60{%else%}0{%endif%}'
    entity_id: cover.rollladen_schlafzimmer_links
    service: cover.set_cover_position
I’m not totally sure about the “float”, but I always get this error:
Error executing script. Invalid data for call_service at pos 1: expected int for dictionary value @ data[‘position’]
If I remove the whole IF ELSE and put position: ‘60’, it works flawlessly.
Can somebody please tell me what I have to change?
Thanks!
Try to modify the " and the ’ like this :
      position: "{% if states('sensor.temp_schlafen')|float >= 24|float %}60{%else%}0{%endif%}"
