I’m looking for testers for a closed Google Play test of a shopping list app for Home Assistant.
The app connects directly to your Home Assistant instance and is aimed at making shared shopping lists simpler and faster to use on mobile.
Current features:
Connects to your Home Assistant instance
Displays and manages your shopping list
Add, check, sort and remove items quickly
Access to all lists configurated in your HA instance
Automatic sync with Home Assistant
Offline caching
If you’d like to join the test, please send me your Google Play email address via private message.
I’ll then send you the opt-in link.
Screenshots are attached below.
I already posted a link to the apk in a previous post, when it was in a very early stage:
(Don’t install the the playstore-version, as it doesn’t include the in app updater.)
But publishing or having people testing it (which would be nice) isn’t the problem or the cause I’m calling for testers.
The main problem is: If you want to publish an app to the Playstore (which I want to) nowadays you need to have at minimum 12 registered testers, which have to install the app and keep it on their phones for at least 14 days. (No joke, that’s all Google wants. No reports, nothing. Just 12 people who install the app. That’s what they call testing, I guess.)
