Cloudflare problem
After update to 2026.3 i cannot open homeassistant on external adres. Via ip adres no problem. It keeps saying loding data a startup
Are you using proxy?
Is proxy running?
Have you checked logs?
Have you tried from other device?
It works well from mij othercontainers. After deleting vm and back to 2026.2.3 everything is working like it schould. Tried 2 times
SOLVED: changed dns name in cloudflare and everything is working as it schould be.
SOLVED: changed dns name in cloudflare. That did it
