My Home Assistant setup works perfectly through Cloudflare until I enable 2FA in Home Assistant itself. Once 2FA is enabled, remote access becomes nearly impossible.
Setup : Home Assistant running in a VM on a Synology NAS
What works:
- Without HA 2FA enabled: everything works perfectly
- With HA 2FA enabled:
- Local network login works correctly
- Remote login through Cloudflare fails after entering the 2FA code
Error message:Unable to connect to Home Assistant.
Retrying in 56 seconds...
Extra:
- Time is correctly synchronized on:
- Phone
- Browser/device
- VM
- Home Assistant
- I would prefer to use Home Assistant’s built-in 2FA instead of Cloudflare Access rules, because Cloudflare authentication works in the browser but not properly in the Android app.
Has anyone experienced this or found a reliable solution?
