Trying to get a CM5 lite installed with HA yellow and M2 drive
When using POE D4 will flash red, D3 flash very briefly green and a coil whine is heard. This will repeat itself every 2 seconds. After troubleshooting this the switch can only provide type 1 POE while it seems type 2 is required. The switch indicates no active POE device on the port.
When the unit is powered by 12V DC D4 flashes 1 time red and never again until the power is removed and reconnected.
When the jumper is set to USB the computer recognizes nothing, when the jumper is set to UART I do get a device CP2102N USB to UART bridge controller but no driver for it.
At this point I’m starting to think the CM5 is DOA, any tips?
Edit:
While this is not mentioned anywhere in the online documentation, the sticker on the bottem of the HA yellow also indicates 802.3af (PoE type 1)
