Has someone already integrated this kind of sensors?
I’m looking for a smaller form factor carbon monoxide sensors then the mq-7.
Push this question up
If you have the MQ-7 or the MQ-2 up and running on an ESP32 for ESPHome, would you mind sharing that code?
And a follow-up Q; If I need to calibrate these components, do you might have some advice for me as to where to find such code too?
MQ sensors are VERY bad ones. Forget it.
What sensor do you recommend to an ESP32 and ESPHome?
Why are MQ7 “so bad”? I mean - in what way? Accuracy? I just installed one in my basement where i have my pellets stove for central heating. I don’t need accuracy there, i just need to know if i’ll “die or stay alive”… ![]()
I successfully integrated the MICS 5524 sensor. As it gives an analog output, we can use the Analog To Digital Sensor, it’s just a bit tricky to figure out the conversion from analog voltage to CO level.
This relation is not straight up given in the datasheet, but there is a diagram that shows the change in resistance relative to the CO-level. There will probably be significant deviations from this graph from sensor to sensor, but this is all we have to get an estimate.
Datasheet shows line in log-log scale, so that means that y = a * x^k, and in our case CO = a * (Rs/R0)^k.
To determine our constants we will take two measurements in the diagram:
CO = 10 ppm @ Rs/R0 = 0.5
CO = 1000 ppm @ Rs/R0 = 0.01
This gives us the following solution:
a = 6.3
k = -1.1
And thus CO = 6.3 * (Rs/R0)^-1.1
Rs is the measured sensing resistance and R0 is its resistance in normal air (at apparently 4.5 ppm CO). The datasheet states that it is somewhere between 100 kΩ and 1500 kΩ, so I assumed R0 = 700 kΩ.
On the usual PCB-Modules, the sensor is typically set up to form a voltage divider with a 10 kΩ resistor to ground. This means that the voltage on the Aout pin is determined by:
Aout = 5V * (10 kΩ) / (Rs + 10 kΩ).
Now, to determine our CO level with our handy formula, we need to calculate the current resistance of Rs, so we rearrange to get this:
Rs = (5V * (10 kΩ) / Aout) - 10 kΩ
Now we can just combine everything into one final formula, to get the CO level of the measured Aout voltage:
CO = 6.3 * (((5V * (10 kΩ) / Aout) - 10 kΩ)/(700 kΩ))^-1.1
Anyways, you’re probably just interested in the configuration, so here it is.
Warning: This sensor is not suitable to get accurate measurements, this configuration will only indicate a rough estimate! Individual sensors may vary significantly in offset and sensitivity, a low reading can not be trusted!
Note: The normal ESP32 can’t read voltages below 0.075V, which results in a minimum measuered CO level of 7 ppm.
- platform: adc
pin: GPIOXX
update_interval: 30s
attenuation: auto
unit_of_measurement: "ppm"
accuracy_decimals: 0
filters:
- lambda: return 6.3f * pow(((5.0f * 10.0f / x) - 10.0f) / 700.0f, -1.1f);
I can confirm that it reacts to alcohol, but I don’t have the means to test and verify that it actually produces semi-accurate CO level readings, so use with caution!
Hi guys, thanks @JensKolb for all your pre-work! I typed in your formula into: Desmos | Graphing Calculator and found your formula did not align with the Grid on the datasheet, so I did a bit of trial and error on the above website to find a formula that is a bit closer to the chart from the MiCS 5524 datasheet.:
3.5 * (Rs)-0.85 or in code terms:
- platform: adc
pin: GPIO32
update_interval: 1s
attenuation: auto
internal: False
unit_of_measurement: "V"
accuracy_decimals: 5
internal: False
update_interval: 1s
#unit_of_measurement: "ppm"
lambda: |-
return (((5.0f * 10.0f / id(volt).state) - 10.0f) / 700.0F);
internal: False
update_interval: 1s
lambda: |-
float co = 3.5f * pow(id(RsR0).state, -0.85f);
if(co < 7) co = 0.0;
if(co > 10000.0) co = 10000.0;
return co;
If somebody have the time to align the other gases, this is how to set up the graph, you just have to play around with the 3.5 and -0.85 to change the graph, it actually is pretty easy now:
Thanks for the heads-up! I quietly switched x and y of the formula (CO and Rs/R0) for simpler transformation.
To recreate the graph in the datasheet, the exact formula would be
(RS/R0) = 3.53553*CO-0.849485.
But we need it the other way around: CO = a*(RS/R0)^k, and that’s what I tried to calculate.
However, I apparently did an error, because the correct values would be a=4.42214, k=-1.17718
I am testing this two sensors MICS-4514 and MICS-5524 and managed to make them work ,this is my config for now
esphome:
friendly_name: "Multi-Gas Detector"
on_boot:
priority: 600
then:
- output.turn_on: heater_control_4514
- output.set_level:
level: 1.0 # 100% duty cycle for MICS-4514 heater
- output.turn_on: enable_5524
- logger.log: "MICS-4514 and MICS-5524 enabled at boot"
esp32:
board: esp-wrover-kit
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ADC_CAL_EFUSE_TP_ENABLE: y
CONFIG_ADC_CAL_EFUSE_VREF_ENABLE: y
CONFIG_ADC_CAL_LUT_ENABLE: y
ota:
platform: esphome
password: !secret ota_password
web_server:
version: 3
logger:
level: INFO
baud_rate: 0 # Disables UART logging (optional)
wifi:
networks:
- ssid: !secret wifi3_ssid
password: !secret wifi3_password
- ssid: !secret wifi_ssid
ap:
ssid: "Gas Sensor Fallback"
password: "xxxxxxxx"
api:
encryption:
key: !secret api_key
services:
- service: restart
then:
- logger.log: "Restart requested via Home Assistant"
- delay: 1s
i2c:
sda: GPIO21
scl: GPIO22
scan: true
ads1115:
- address: 0x48
continuous_mode: true
output:
- platform: ledc
pin: GPIO2
frequency: 100Hz # Suitable for MICS-4514 heater control
- platform: gpio
pin: GPIO4
binary_sensor:
- platform: status
button:
name: "Start Calibration"
on_press:
then:
- output.set_level:
level: 1.0
- delay: 180s # 3-minute warm-up
- lambda: |-
float rs_red = id(mics_rs_red_4514).state;
float rs_ndx = id(mics_rs_ndx_4514).state;
float rs_5524 = id(mics_rs_5524).state;
if (!isnan(rs_red) && rs_red > 1000 && rs_red < 50000 &&
!isnan(rs_ndx) && rs_ndx > 1000 && rs_ndx < 50000 &&
!isnan(rs_5524) && rs_5524 > 1000 && rs_5524 < 50000) {
id(mics_ro_red_4514) = rs_red;
id(mics_ro_ndx_4514) = rs_ndx;
id(mics_ro_5524) = rs_5524;
ESP_LOGI("calib", "New baselines: RED_4514=%.0f Ohms, NDX_4514=%.0f Ohms, 5524=%.0f Ohms", rs_red, rs_ndx, rs_5524);
} else {
ESP_LOGE("calib", "Invalid Rs: RED_4514=%.0f Ohms, NDX_4514=%.0f Ohms, 5524=%.0f Ohms", rs_red, rs_ndx, rs_5524);
time:
- platform: homeassistant
globals:
- id: invalid_reading_minutes
type: int
restore_value: no
initial_value: '0'
- id: mics_ro_red_4514
type: float
restore_value: true
initial_value: '10000.0'
- id: mics_ro_ndx_4514
type: float
restore_value: true
- id: mics_ro_5524
type: float
restore_value: true
interval:
- interval: 1min
then:
- lambda: |-
if (isnan(id(mics_rs_red_4514).state) || isnan(id(mics_rs_ndx_4514).state) || isnan(id(mics_rs_5524).state)) {
id(invalid_reading_minutes) += 1;
ESP_LOGW("check", "Rs is invalid for %d minute(s)", id(invalid_reading_minutes));
} else {
id(invalid_reading_minutes) = 0;
if (id(invalid_reading_minutes) >= 5) {
ESP_LOGE("check", "Rs invalid for 5+ minutes. Restarting...");
App.reboot();
bme68x_bsec2_i2c:
address: 0x77
model: bme680
operating_age: 28d
sample_rate: LP
supply_voltage: 3.3V
- platform: ads1115
ads1115_id: ads
multiplexer: A0_GND
gain: 4.096 # Suitable for 0–4.096V; use 6.144 if Vout exceeds 4.096V
update_interval: 5s
name: "MICS-4514 RED Vout"
accuracy_decimals: 4
filters:
- median:
window_size: 5
send_every: 2
- sliding_window_moving_average:
window_size: 10
send_every: 5
- platform: ads1115
ads1115_id: ads
multiplexer: A1_GND
gain: 4.096
update_interval: 5s
name: "MICS-4514 NDX Vout"
filters:
- median:
window_size: 5
send_every: 2
window_size: 10
send_every: 5
- platform: ads1115
ads1115_id: ads
multiplexer: A2_GND
gain: 4.096
update_interval: 5s
filters:
- median:
window_size: 5
send_every: 2
window_size: 10
send_every: 5
- platform: bme68x_bsec2
temperature:
name: "BME68x Temperature"
pressure:
name: "BME68x Pressure"
humidity:
name: "BME68x Humidity"
iaq:
co2_equivalent:
name: "BME68x CO2 Equivalent"
breath_voc_equivalent:
name: "BME68x Breath VOC Equivalent"
- platform: wifi_signal
update_interval: 60s
- platform: uptime
name: "MICS-4514 RED Rs"
unit_of_measurement: "Ohms"
update_interval: 10s
lambda: |-
float vout = id(mics_vout_red_4514).state;
if (vout > 0.1 && vout < 4.9) {
return 820.0 * (5.0 / vout - 1);
ESP_LOGE("sensor", "Invalid MICS-4514 RED Vout: %.2fV", vout);
return NAN;
name: "MICS-4514 NDX Rs"
lambda: |-
float vout = id(mics_vout_ndx_4514).state;
ESP_LOGE("sensor", "Invalid MICS-4514 NDX Vout: %.2fV", vout);
return NAN;
lambda: |-
float vout = id(mics_vout_5524).state;
ESP_LOGE("sensor", "Invalid MICS-5524 Vout: %.2fV", vout);
return NAN;
name: "MICS-4514 RED Rs/Ro Ratio"
lambda: |-
float rs = id(mics_rs_red_4514).state;
float ro = id(mics_ro_red_4514);
if (isnan(rs) || isnan(ro) || ro <= 0) {
return NAN;
return rs / ro;
name: "MICS-4514 NDX Rs/Ro Ratio"
lambda: |-
float rs = id(mics_rs_ndx_4514).state;
float ro = id(mics_ro_ndx_4514);
return NAN;
return rs / ro;
name: "MICS-5524 Rs/Ro Ratio"
lambda: |-
float rs = id(mics_rs_5524).state;
float ro = id(mics_ro_5524);
return NAN;
return rs / ro;
name: "MICS-4514 Carbon Monoxide (CO)"
accuracy_decimals: 1
lambda: |-
float ratio = id(rs_ro_ratio_red_4514).state;
return isnan(ratio) ? NAN : 0.08 * pow(ratio, -2.95) * exp(1.77 * log(ratio));
name: "MICS-4514 Methane (CH4)"
lambda: |-
return isnan(ratio) ? NAN : 0.85 * pow(ratio, -2.61) * exp(1.62 * log(ratio));
name: "MICS-4514 Ethanol (C2H5OH)"
lambda: |-
return isnan(ratio) ? NAN : 0.10 * pow(ratio, -3.14) * exp(2.43 * log(ratio));
name: "MICS-4514 Hydrogen (H2)"
lambda: |-
return isnan(ratio) ? NAN : 0.04 * pow(ratio, -1.8) * exp(0.9 * log(ratio));
name: "MICS-4514 Ammonia (NH3)"
lambda: |-
return isnan(ratio) ? NAN : 0.10 * pow(ratio, -1.67) * exp(0.87 * log(ratio));
name: "MICS-4514 Nitrogen Dioxide (NO2)"
accuracy_decimals: 2
lambda: |-
float ratio = id(rs_ro_ratio_ndx_4514).state;
return isnan(ratio) ? NAN : 1.8 * pow(ratio, 1.18) * exp(-0.35 * log(ratio));
name: "MICS-5524 Carbon Monoxide (CO)"
lambda: |-
float ratio = id(rs_ro_ratio_5524).state;
return isnan(ratio) ? NAN : 0.25 * pow(ratio, -2.95) * exp(1.77 * log(ratio));
name: "MICS-5524 Methane (CH4)"
lambda: |-
return isnan(ratio) ? NAN : 2.4 * pow(ratio, -2.61) * exp(1.62 * log(ratio));
name: "MICS-5524 Ethanol (C2H5OH)"
lambda: |-
return isnan(ratio) ? NAN : 0.15 * pow(ratio, -3.14) * exp(2.43 * log(ratio));
name: "MICS-5524 Hydrogen (H2)"
lambda: |-
return isnan(ratio) ? NAN : 0.10 * pow(ratio, -1.8) * exp(0.9 * log(ratio));
name: "MICS-5524 Ammonia (NH3)"
lambda: |-
return isnan(ratio) ? NAN : 0.17 * pow(ratio, -1.67) * exp(0.87 * log(ratio));
name: "MICS-5524 Nitrogen Dioxide (NO2)"
lambda: |-
return isnan(ratio) ? NAN : 0.13 * pow(ratio, 1.18) * exp(-0.35 * log(ratio));
Hardware Setup
I have the MiCS-4514 - DFRobot. I noticed your NO2 values and wanted to ask if you looked into those numbers? Mine is a constant .16ppm and looking online, that value is cause for alarm. I think it is because mine isn’t calibrated, but I wanted to see if others have noticed anything with their values.
@stburnett Mine is installed in my vented attic next to two HVAC systems. When on heat mode they burn gas.
This is what my Nitrogen Dioxide shows:
Another sensor that seems stuck is the CO sensor as it is always around 4ppm however I read that 0.5 to 5ppm is the typical reading for outdoors and anything below 9ppm of CO is safe. Either way, I am not too sure how much I can rely on the MICS 4514 sensor for safety. Looking for esphome compatible alternatives especially for Carbon Monoxide…
Good luck with that. There are very few of them… if you do find it please let us know. But, i’d say that this MICS is more or less the best available (for monoxide and esphome).
