Code called async_timeout.timeout with loop keyword argument - please report
[Edit] This is a known issue - see https://github.com/home-assistant/core/issues/62186
I get the following warning in my Home Assistant Log after a re-start. This appears to be related to the pyenvisalink package.
2022-01-09 10:04:51 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that called async_timeout.timeout with loop keyword argument. The loop keyword argument is deprecated and calls will fail after Home Assistant 2022.2. Please report this issue.
Stack (most recent call last):
File "/usr/local/lib/python3.9/runpy.py", line 197, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.9/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 331, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 318, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 121, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 629, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 596, in run_forever
self._run_once()
File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1890, in _run_once
handle._run()
File "/usr/local/lib/python3.9/asyncio/events.py", line 80, in _run
self._context.run(self._callback, *self._args)
File "/usr/local/lib/python3.9/site-packages/pyenvisalink/envisalink_base_client.py", line 61, in connect
async with async_timeout.timeout(self._alarmPanel.connection_timeout, loop=self._eventLoop):
File "/usr/src/homeassistant/homeassistant/async_timeout_backcompat.py", line 19, in timeout
report(
File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 74, in report
_LOGGER.warning(msg, stack_info=True)
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
Hi, was there any update on that? I am also getting this when restart…
Logger: homeassistant.helpers.frame
Source: helpers/frame.py:74
First occurred: 12:15:25 (1 occurrences)
Last logged: 12:15:25
