Code issues in a template with a loop
Hello everyone. Following a tutorial from Smart Home Junkie, I made Templates to return the expected rainfall per day, using the openweathermap API. however the template explained does not work. This is apparently the part with
{% for daypart in range(0 ,7) %}
This part gives me a problem.
# essai "Météo de la journée selon Smart Home Junkie"
- trigger:
    - platform: homeassistant
      event: start
    - platform: time_pattern
      minutes: /20
    - service: weather.get_forecast
        type: hourly
        entity_id:
          - weather.openweathermap
      response_variable: my_forcast
    - name: "Météo of the day by Smart Home Junkie"
      unique_id: 14485d6d-fb53-4e72-aea6-85f613b015ee
      icon: mdi:weather-pouring
      unit_of_measurement: mm
      state: >
        {% set ns = namespace() %}
        {% set ns.totalprecipitation = 0 %}
          {% set precipitation = my_forcast.forecast[daypart].precipitation %}
          {% set precipitation_probability = my_forcast.forecast[daypart].precipitation_probability / 100 %}
          {% if precipitation_probability > 0 %}
           {% set precipitation = precipitation * precipitation_ probability %}
          {% endif %}
          {% set ns.totalprecipitation = ns.totalprecipitation + precipitation %}
        {% endfor %}
        {{ ns.totalprecipitation |  float(0) | round(2) }}
Any idea what my code is missing???
I circumvented with the sum of [daypart] by replacing [daypart] with [0],…,[7]
Thank you for your suggestions.
  1. You’re missing {% set my_forcast = states.weather.owm_daily.attributes %}
  2. You have a bogus blank after the underscore in {% set precipitation = precipitation * precipitation_ probability %}
   {% set precipitation = precipitation * precipitation_probability %}
  {% endif %}
{% endfor %}
