Code Server addon keyboard layout keeps changing to US
VS Code - Code server addon works well on my windows 10 pc, except the layout always setting back to US.
Keybd Layout is shown bottom right of the window.
When I click on it, options become available. It shows current setting as auto detect : US. Which is wrong as I use a french keybd.
I can not change the layout directly to french. I must select Belgian first and then again select French to actually change. Weird !
Next restart will bring back to US.
It is noticeable that the keyboard keys are correct when I type, even if Layout is set to US. But the shortcuts are not. Ctrl-C/Ctrl-V for instance will not work.
Is this a bug or do I miss something ?
