This code which can also be found in github (GitHub - pmr1/home_assistant: Code and design relating to home assistant) allows a two component authorisation to a door lock controlled an esp8266. The automation is given here
alias: Un lock Front Door
description: security door control actions
triggers:
- trigger: state
entity_id:
- script.lock_front_door_2
to: null
conditions:
- condition: and
conditions:
- condition: template
value_template: "{{ states('input_text.text1') | regex_match('xxxxxx') }}" # code 1
value_template: "{{ states('input_text.text2') | regex_match('y.yyy') }}" # code 2
actions:
- type: turn_on
device_id: f757fad91cc2dd9857bd4c4c2ec1d4be
entity_id: 9ee6947d79b05e44c1d7fcd4f2abf43a
domain: switch
- action: notify.notify
metadata: {}
message: Front Door accessed
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
# this section wipes the code entered on the overview after use
- data:
value: "\"\""
entity_id: input_text.text1
action: input_text.set_value
- data:
value: "\"\""
entity_id: input_text.text2
mode: single
The automation is triggered by a simple script.The design of the esp8266 module can be found here https://github.com/pmr1/home_assistant/design
