Hugh1978
(Hugh)
1
Good day.
I need help with coding my RF devices to in configuration. yaml
This is the info I receive on Tasmota console:
14:55:33.044 MQT: tele/RF_Bridge/RESULT = {“Time”:“2021-02-28T14:55:33”,“RfReceived”:{“Sync”:12560,“Low”:440,“High”:1240,“Data”:“D4027E”,“RfKey”:“None”}}
This is a motion sensor.
tteck
(𝙩𝙩𝙚𝙘𝙠𝙨𝙩𝙚𝙧)
2
Maybe
binary_sensor:
- platform: mqtt
state_topic: "tele/RF_Bridge/RESULT"
value_template: >-
{% if value_json.RfReceived.Data == 'D4027E' %}
{{'ON'}}
{% else %}
{{states('binary_sensor.motion_sensor') | upper}}
{% endif %}
device_class: motion
qos: 1
off_delay: 10
Hugh1978
(Hugh)
3
Thanks allot, I will try this and let you know
Hugh1978
(Hugh)
4
Thanks allot, this coding is working 100%
Hugh1978
(Hugh)
5
Do you perhaps have a coding for a door contact
tteck
(𝙩𝙩𝙚𝙘𝙠𝙨𝙩𝙚𝙧)
6
What’s the Tasmota console message?
Hugh1978
(Hugh)
7
This is when I open the door
17:06:30.281 MQT: tele/RF_Bridge/RESULT = {“Time”:“2021-02-28T17:06:30”,“RfReceived”:{“Sync”:7950,“Low”:270,“High”:780,“Data”:“CD94B1”,“RfKey”:“None”}}
This is when the door close
17:06:56.383 MQT: tele/RF_Bridge/STATE = {“Time”:“2021-02-28T17:06:56”,“Uptime”:“0T03:10:09”,“UptimeSec”:11409,“Heap”:27,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“Wifi”:{“AP”:1,“SSId”:“Meadowbrook-Guest 2G”,“BSSId”:“58:C1:7A:11:66:80”,“Channel”:1,“RSSI”:84,“Signal”:-58,“LinkCount”:1,“Downtime”:“0T00:00:03”}}
tteck
(𝙩𝙩𝙚𝙘𝙠𝙨𝙩𝙚𝙧)
8
binary_sensor:
- platform: mqtt
value_template: >-
{% if value_json.RfReceived.Data == 'CD94B1' %}
{{'ON'}}
{% else %}
{{states('binary_sensor.door_sensor') | upper}}
{% endif %}
device_class: door
qos: 1
EDIT: deleted off_delay
