I installed in garden nice color lamps connected with Hue.
Various app give a nice colour loop functionality (color changes within a spectrum, with changeable transition time).
Is this possible in HA?
You can use the light.turn_on
service while supplying the option effect: colorloop
. This is something you can do through a script or an automation.
However, I don’t think you can influence the speed of the colorloop. You can supply a value for transition:
but this only defines how long it should take the light to get from the old state to the new state (e.g. from off to colorlooping at 100% brightness).
Can you please give me a simple code. I don’t need automation, just a switch
I quickly put together the following script example:
office_moodlight:
sequence:
- service: light.turn_on
entity_id: light.lightstrip_desk
effect: colorloop
brightness: 127
transition: 5
So if I were to add script.office_moodlight
to my HASS interface, then I get a “ACTIVATE” button to turn on the lightstrip with colorloop effect.
What I add in configuration, something like this (my light is garden_right)?
script.garden_moodlight:
sequence:
entity_id: light.garden_right
effect: colorloop
brightness: 254
transition: 5
I get this error
16-12-10 13:49:59 homeassistant.loader: Unable to find component garden_moodlight
I find it complicate, I still don’t understand how it all works
Replace the dot with a space in script.garden_moodlight
script garden_moodlight:
sequence:
effect: colorloop
brightness: 254
transition: 5
thabks, I did this, now is working
script:
garden_moodlight:
sequence:
effect: colorloop
brightness: 254
transition: 5
