Color_temp: for Sengled Smart LED Tunable White A19 Bulbs?
I have 2 x Sengled Smart LED Tunable White A19 Bulbs but there is no Color Temperature slider, The devices are named “light.sengled_z01_a19nae26_906c0103_level_light_color_on_off” and “light.sengled_z01_a19nae26_43100103_level_light_color_on_off”… to me light_color should mean color_temp would be available…
  "node_descriptor": "<NodeDescriptor byte1=2 byte2=64 mac_capability_flags=140 manufacturer_code=4448 maximum_buffer_size=82 maximum_incoming_transfer_size=82 server_mask=0 maximum_outgoing_transfer_size=82 descriptor_capability_field=0>",
  "endpoints": {
    "1": {
      "profile_id": 260,
      "device_type": "0x0101",
      "in_clusters": [
        "0x0000",
        "0x0003",
        "0x0004",
        "0x0005",
        "0x0006",
        "0x0008",
        "0x0300",
        "0x0702",
        "0x0b05"
      "out_clusters": [
        "0x0019"
  "manufacturer": "sengled",
  "model": "Z01-A19NAE26",
  "class": "zigpy.device.Device"
My OSRAM Lightify A19 Tunable While bulb does have a color temperature slider:
  "node_descriptor": "<NodeDescriptor byte1=1 byte2=64 mac_capability_flags=142 manufacturer_code=48042 maximum_buffer_size=64 maximum_incoming_transfer_size=0 server_mask=0 maximum_outgoing_transfer_size=0 descriptor_capability_field=3>",
  "endpoints": {
    "3": {
      "profile_id": 260,
      "device_type": "0x0102",
      "in_clusters": [
        "0x0000",
        "0x0003",
        "0x0004",
        "0x0005",
        "0x0006",
        "0x0008",
        "0x0300",
        "0x0b04",
        "0xfc0f"
      "out_clusters": [
        "0x0019"
  "manufacturer": "OSRAM",
  "model": "LIGHTIFY A19 Tunable White",
  "class": "zhaquirks.osram.a19twhite.A19TunableWhite"
This works with the Sengled Hub. Its not local control but could help others.
Sengledapi
I also have this problem. I don’t have a hub and would rather not have one. Has there been and updates on trying to get colour temperature working on Home Assistant?
I’m using this with ConBeeII + deConz
I’m using with zzh CC2652R stick and zigbee2mqtt.
The color temp slider only appears when the bulb is on.
