Dear all -
I recently started with Home Assistant and the options are just overwhelming (amazing)!
Yesterday, I created two automations that will publish a value to start loading my PV battery from the grid. Each automatization by itself works if I fire them manually.
Now I’d like to combine both in one switch button.
If I activate the switch button → Fire Automatization “ON”
If I deactivate the switch button → Fire Automatization “OFF”
Could you help me to find the best solution for implementation / configuration?
Automatization “ON”:
alias: Batterie Netzladen An
description: “”
triggers:
conditions:
actions:
- action: mqtt.publish
metadata: {}
qos: 0
retain: false
topic: evcc/site/batteryGridChargeLimit/set
payload: “0.30”
mode: single
Automatization “OFF”:
alias: Batterie Netzladen Aus
description: “”
triggers:
conditions:
actions:
metadata: {}
qos: 0
retain: false
payload: “-0.30”
mode: single
Thanks in advance
