I’m trying to combine two sensors in to one lovelace history graph - but no matter what I do it shows in two separate graphs:
Any ideas what I’m doing wrong?
One’s an integer and the other’s a float, I don’t think it’ll put them on the same graph if they aren’t the same type of variable. I’d bug report it as they are technically comparable as they’re both numbers.
I have same problem… 0.94
Any luck finding a solution to this? I am seeing this as I have a mix of: Hue Motion sensors (temp) Aqara Temp sensors
