Combine multiple Sensibo climate services in one action?
New to this, so i am hopeing there is an easy solution, but have not found it yet.
I use a Sensibo which i can control via the Climate service.
I would like to set a number of parameters in a single action.
My code works fine, but each service call (5 in total currently) runs in sequence, meaning my Air Conditioner beeps 5 times, each about a second appart, kinda annooying.
Is there a way to combine all into a single ‘message’ or is it not possible as each is a different sub service of climate?
alias: Harrison_CR_On_HighTempCheck
description: ''
mode: single
  - platform: state
    entity_id: input_boolean.climate_react_harrison
    to: 'on'
condition:
  - condition: numeric_state
    entity_id: climate.harrison_bedroom
    attribute: current_temperature
    above: input_number.climate_react_harrison_max_temp
  - service: climate.turn_on
  - service: climate.set_fan_mode
      fan_mode: quiet
  - service: climate.set_swing_mode
      swing_mode: rangeFull
  - service: climate.set_hvac_mode
      hvac_mode: cool
  - service: climate.set_temperature
    data_template:
      temperature: '{{ states(''input_number.climate_react_harrison_set_temp'') | float }}'
Welcome to the forum.
I don’t think you can with the normal sensibo. I agree, annoying.
If you used an IR blaster you could capture some commonly used settings and send them in one lot.
Yeah its annoying because their app can do it, just seems that the api treats each service as a single web broadcast.
So there is no way multiple services to a single target can be ‘grouped’ into one message?
