I have set up the following entities:
Modbus light
This is a relay in a PLC that switches the power to the light on and off. This relay is also switched by a physical switch.
DMX CW/WW Fader
Can change the color temperature and brightness of this light.
Cannot be physically switched/changed.
Now I need an entity for the front end. Since I physically switch the power via a relay, the lamp turns on and off quickly, but the DMX dimmer must always remain set to the last value and not be dimmed to 0% when switched off.
How do I do that? The entity should still always have the correct status of the light.
What I have already tried:
light group
Virtual Components and rules
helper light
Can anyone point me in the right direction?
Translated with DeepL.com (free version)
