Combined Lock & Door Status in single Entity for Glance Card?
Update, looks like the way templates works will be changing in 2026 - you will get warnings in the GUI with ways to fix it. It is nice that the GUI gives you the fix, but by way of example:
So this old code:
    sensors:
      breezeway_door_status_sc:
        friendly_name: "Breezeway Door Status"
        unique_id: breezeway-door-status-2ad4a16a-3d68-48bb-11f8-491226726111
        value_template: >-
          {% if ( (is_state('lock.breezeway','unlocked')) and (is_state('binary_sensor.door_breezeway_window_door_is_open','off')) ) %}
            Unlocked
          {% elif ( (is_state('binary_sensor.door_breezeway_window_door_is_open','on')) and (is_state('lock.breezeway','locked')) ) %}
            Locked Open
          {% elif ( (is_state('binary_sensor.door_breezeway_window_door_is_open','off')) and (is_state('lock.breezeway','locked')) ) %}
            Locked
          {% elif ( (is_state('binary_sensor.door_breezeway_window_door_is_open','on')) and (is_state('lock.breezeway','unlocked')) ) %}
            Open
          {% else %}
            Unknown
          {% endif %}
        icon_template: >-
            mdi:lock-open
            mdi:door-closed-cancel
            mdi:lock
            mdi:door-open
          {% else %}
            mdi:lock-question
          {% endif %}
Becomes this:
- sensor:
  - unique_id: breezeway-door-status-2ad4a16a-3d68-48bb-11f8-491226726111
    default_entity_id: sensor.breezeway_door_status_sc
    icon: "{% if ( (is_state('lock.breezeway','unlocked')) and (is_state('binary_sensor.door_breezeway_window_door_is_open','off'))
      ) %}\n  mdi:lock-open\n{% elif ( (is_state('binary_sensor.door_breezeway_window_door_is_open','on'))
      and (is_state('lock.breezeway','locked')) ) %}\n  mdi:door-closed-cancel\n{%
      and (is_state('lock.breezeway','locked')) ) %}\n  mdi:lock\n{% elif ( (is_state('binary_sensor.door_breezeway_window_door_is_open','on'))
      and (is_state('lock.breezeway','unlocked')) ) %}\n  mdi:door-open\n{% else %}\n
      \ mdi:lock-question\n{% endif %}"
    name: Breezeway Door Status
    state: "{% if ( (is_state('lock.breezeway','unlocked')) and (is_state('binary_sensor.door_breezeway_window_door_is_open','off'))
      ) %}\n  Unlocked\n{% elif ( (is_state('binary_sensor.door_breezeway_window_door_is_open','on'))
      and (is_state('lock.breezeway','locked')) ) %}\n  Locked Open\n{% elif ( (is_state('binary_sensor.door_breezeway_window_door_is_open','off'))
      and (is_state('lock.breezeway','locked')) ) %}\n  Locked\n{% elif ( (is_state('binary_sensor.door_breezeway_window_door_is_open','on'))
      and (is_state('lock.breezeway','unlocked')) ) %}\n  Open\n{% else %}\n  Unknown\n{%
      endif %}"
I also took all of these and combined them into a singular template.yaml and then referenced it in the main configuration.yaml with:
template: !include template.yaml
