Combining entities into a device
Hi there!
I’m trying to figure out whether there is a way to combine multiple manually configured entities into a single device.
The only reference in documentation I got was this:
Device Registry | Home Assistant Developer Docs (home-assistant.io)
The documentation, however, does not specify how to do this through yaml or frontend, but a “developer way.”
Any info on this would be highly appreciated.
Thank you.
You can’t.
The only option that exists is for MQTT entities, using MQTT Discovery.
