Combining RGB with CWW light
I’m a bit stuck,
I have a light with warm white and RGB,
but as of now those are 2 separate entities.
but I want to use only 1.
So my thought was to create a 3th light and then sync the colors.
but when I do this. none of the colors work.
I have this now
bk72xx:
  board: generic-bk7231n-qfn32-tuya
globals:
  - id: sync_r
    type: float
    restore_value: no
    initial_value: "0.0"
  - id: sync_g
    type: float
    restore_value: no
  - id: sync_b
    type: float
    restore_value: no
  - id: sync_lock
    type: bool
    restore_value: no
    initial_value: "false"
output:
  - platform: libretiny_pwm
    pin: P26
    pin: P24
    type: float
    write_action:
      # no-op
      - lambda: |-
    type: float
    write_action:
      # no-op
      - lambda: |-
    type: float
    write_action:
      # no-op
      - lambda: |-
light:
  # - platform: cwww
  #   id: light_cwww
  #   name: Light
  #   cold_white_color_temperature: 6500 K
  #   warm_white_color_temperature: 2700 K
  #   cold_white: output_cold
  #   warm_white: output_warm
  - platform: beken_spi_led_strip
    pin: P16
    chipset: sm16703
    num_leds: 12
    rgb_order: RGB
    on_state:
      then:
        - lambda: |-
            if (id(sync_lock)) return;
            id(sync_lock) = true;
            id(sync_r) = id(rgb_raw).current_values.get_red();
            id(sync_g) = id(rgb_raw).current_values.get_green();
            id(sync_b) = id(rgb_raw).current_values.get_blue();
            auto call = id(light_rgbww).make_call();
            call.set_red(id(sync_r));
            call.set_green(id(sync_g));
            call.set_blue(id(sync_b));
            call.perform();
            id(sync_lock) = false;
  - platform: rgbww
    color_interlock: true
    red: output_red
    green: output_green
    blue: output_blue
    restore_mode: ALWAYS_ON
    on_state:
      then:
        - lambda: |-
            id(sync_r) = id(light_rgbww).current_values.get_red();
            id(sync_g) = id(light_rgbww).current_values.get_green();
            id(sync_b) = id(light_rgbww).current_values.get_blue();
            auto call = id(rgb_raw).make_call();
            call.set_rgb(id(sync_r), id(sync_g), id(sync_b));
            call.perform();
the global sync_r etc I probably can set local,
but that won’t fix my issue.
anyone any suggestions?
I think I either read or write the colors wrong
Before you go off and do a whole bunch of over thinking and making a minor problem into a massive one, you need to do the most important step and thats to go check through the Esphome documentation for solutions that may already exist for this or any problem because it would have saved you all this extra unnecessary code you made…
Also, what specific type of device/hardware are you using?
Sorry for replying this late,
I went with openBeken and forgot about this post.
but openbeken doesn’t seem to be stable enough so I am here again.
I know about the RGBWW light,
but that needs a spit RGB, and the ledstrip is not providing this.
    red: output_component1
    green: output_component2
    blue: output_component3
so that’s why I can’t be used this way.
using it this way would be awesome.
My current setup is like this
light:
    icon: mdi:palette
    pin: P16
    chipset: sm16703
    num_leds: 12
    rgb_order: RGB
    restore_mode: ALWAYS_OFF
    effects:
      - addressable_rainbow:
      - addressable_color_wipe:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
      - random:
      - pulse:
          transition_length: 1s
          update_interval: 1s
      - strobe:
      - flicker:
    on_turn_on:
      - light.turn_off: white_light
      - if:
          condition:
            switch.is_on: enable_timer
          then:
            - script.execute: turn_off_timer
    on_turn_off:
      - if:
          condition:
            light.is_off: white_light
          then:
            - script.stop: turn_off_timer
  - platform: cwww
    icon: mdi:wall-sconce-flat-outline
    on_turn_on:
      - light.turn_off: rgb_strip
      - if:
          condition:
          then:
    on_turn_off:
      - if:
          condition:
            light.is_off: rgb_strip
          then:
but that means still 2 lights.
1 would be awesome.
the light I have actually is this one
https://www.elektroda.com/rtvforum/topic4095226.html
