I am completely dumb when it comes to YAML coding, so I am trying to get help here.
I have one card showing if my phone is Home or Away based on device_tracker. The entity name is ‘device_tracker.erics_samsung_flip5’.
I also have one card showing in which room the phone is based on Bermuda BLE Trilateration. The entity name is ‘sensor.bermuda_eric_area’.
I have different rooms defined as areas, and the ‘sensor.bermuda_eric_area’ do show up correctly.
They both work separately, but how can I get them on the same card, so that it:
- shows Away when ‘device_tracker.erics_samsung_flip5’ is not in the Home zone
- shows in what room it is when ‘device_tracker.erics_samsung_flip5’ is in the Home zone
Advice is much appreciated. thank you!
tom_l
2
The easiest way would be to create a combined template sensor. The entity ids you supplied make it very easy to give you an example config for this,
configuration.yaml
template:
- sensor:
- name: "Erics Phone Location"
icon: >
{% if is_state('device_tracker.erics_samsung_flip5','home') %}
mdi:floor-plan
{% else %}
mdi:cellphone-marker
{% endif %}
state: >
{{ states('sensor.bermuda_eric_area') }}
{% else %}
{{ state_translated('device_tracker.erics_samsung_flip5') }}
{% endif %}
If this is the first time you have created a template sensor you will need to restart Home Assistant.
Then you can put sensor.erics_phone_location
in your dashboard.
tom_l
3
This works BTW. I implemented it myself.
I used a changing icon co I could see with a quick glance the source of the location.
